I've been combing the internet, and can't find a direct answer to my question, but now I'm wondering:
Here's where I'm going with this:
Let's say I create a file of 20 POIs that have a proximity alert of 10 miles. Keep in mind, if you use POI loader (and not CSV) you have to assign the same alert distance to all points in the file when you load 'em.
Then, let's say I create a file of 5 more POIs, and load those with a prox alert of 50 miles.
Will loading additional POI overwrite the old POI? I seem to think you can actually add POI because when you power up the Zumo after a load, it prompts to manage new data, and if I loaded more POI without removing the old... it should just add under a different import group... even though they'd ALL be in the Zumo... right?
Can you ADD POI files to your Zumo or will adding a POI file REPLACE existing POI?
