Went out for a ride and when I went to use the rear brake, it was WAY soft. Went back to the house and found fluid leaking from the delay valve assembly on the front fork. A quick check found that the fluid is leaking from one of the fittings. I have not had the time to take it apart yet, but was wondering if anyone else has had a problem with the valve leaking. If it just needs a new washer, then I will fix it myself. If it is something major (new valve), then it will go to the STealer for repairs under warranty.
