* thermostate sticking - CHECK
* electric windshield gears stripping - CHECK this is the Warranty Justifier!!!
* misc coolant leaks - ONE TIME SHOT. Essentially a "breaking in" matter.
* rear wheel bearing failure
* bike pulls to the right - huh?
* high speed wobble - Never experienced even in triple digits, two up with trailer.
* high heat from engine - varies by bike, and by your definition of "high heat". Legitimate complaint, but not a mechanical/breakdown issue, simply a comfort/tolerance issue. Like the seat.
The first three are the most common, #1 & #2 are, 8 years into the production of the bike, inexcusable from Honda. #2 wouldn't actually be that big of a deal, except that to restore functionality when the $5 plastic worm gear strips, you have to replace the entire mechanism at a cost upwards of $400!!! Honda simply doesn't make the parts available separately. Thermostat sticking, only because Honda is too pigheaded to re-spec the cheap crappy t-stat and use a decent one. These two failings really ding that "legendary Honda engineering and constant improvement" myth.
