I was checking my valves today and my feeler gauges fell apart in my hand, right as I was checking them..
I was thinking.... where is the nut? uh oh.....
Luckily.... if fell in a good spot...
Yeah....but where's the fiction washer?
<D>
That will give you a chance to make a custom set just for checking valves, assemble the pieces you need and set the rest aside.
I made my own custom ones by bending flat ones up about 1/2" from the tip. They still go back together and close up just fine.I wouldn't use these if that were the case, you really need the angled ones especially for some of the exhaust valves...
TIP- stuff paper towel pieces into the openings. Keeps thing from falling into the engine. Just remember to remove them when finished.
We need to take this post one step farther. What would you have done if indeed the small nut filtered its way to the crankcase??? The oil pump pickup tube probably has a screen on it. Would the nut remain on the bottom, never to cause a problem? Would the nut be thrown around due to windage and g-forces causing your entire crankcase, rods, crank, trans gears to be shot peened?
Joe, I am going to recommend you open up that valve cover again and throw that little nut in there so the rest of us know what to do if it ever happens to us.
Thanks in advance. :work5:
