ardykay54
Russ "NeonMan" Knock
- Joined
- Apr 27, 2008
- Messages
- 1,151
- Age
- 69
- Location
- Hopkinton, Iowa
- Bike
- 22 Kaw Z900rs 50 ann
- 2024 Miles
- 002718
- STOC #
- 7581
Stick with the OEM T-stat! I've replaced an aftermarket one a week later in another members bike.
When you replaced yours, did you flush the coolant system out and make sure to clean all the black paint off the radiator pipes (inside) when you did it?
There have been several members, as well as myself who've found black paint inside the t-stat jamming them open. Once I've removed the paint (scotchbrite pad) I've not had any further issues.
I replace my T-stat about once a year when I flush the coolant just as a preventative measure.
I figure I'm in there flushing the coolant, might as well replace everthing.
Good time to replace the coolant hoses with better ones too.
.02
I did use a Honda thermostat, flushed, and cleaned off some overspray. Filled with the Prestone long life coolant.(Silicate free) Are all Honda parts created equally?(Bad new themostat?) Would you still change coolant yearly if you used the Prestone coolant? Better hoses? Honda hoses or other? Thanks. Russ.
