Joined the "Stripped Oil Drain Plug" group today.
sirepair
sirepair
Let's RIDE!
Chillicothe, Ohio
2003 ST1100P
7105
I dunno Pat, how will you keep the drill bit and tap straight and true? I kinda like the oversized plug better. At least if it fails you can always turn to the drill/tap...
It's a non-stressed (well, other than the torque on the plug) fastener; not super critical to be precise. As long as the hole isn't "wallered" out, it should be OK. I have access to the same tooling that is used for Honda auto parts mfg (I work at a tier 1 supplier) so a good, sharp bit and tap won't be a problem! Just have to make sure that I don't drink too much caffeine before "surgery"!
Newport News, VA
2006 ST1300A
Yes, and they're preferred over Helicoils for use in aluminum because they're a solid machined piece versus a wound piece of wire. Timeserts best attribute is that they require minimal drilling oversize because the insert's external threads are not much larger in diameter than the internal threads. In fact, they're called "Time"-serts because the internal & external threads are "timed" with each other when machined. When I needed an insert where external thread size is not much concern, I made my own by drilling/tapping through the center of a length of all-thread or through a bolt.
The Dan
The Dude Abides
Vendor
Watertown SD
2009 ST1300 ABS
7982
NAPA has them in stock if you get in a jam and need one fast......and yes 12x1.25 is the correct size DUH!!!! My memory is shot.
BakerBoy
It's all small stuff.
Golden, Colorado
1408
Per the ST1300 parts catalog, the ST1300 drain plug is a "BOLT, DRAIN PLUG (14MM)", part number 90004-MCS-000. Anyone know the thread pitch?
Edit: Per the 1998 ST1100A fiche, a ST1100 a drain plug is a "BOLT, DRAIN (12MM)", part number 92800-12000. Per above posts, it has a 1.25 thread pitch (ie, is a 12x1.25 thread).
sirepair
sirepair
Let's RIDE!
Chillicothe, Ohio
2003 ST1100P
7105
14mm pitch is probably 1.5, at least the plug that I got is. Pretty common plug.
T_C
St. Louis, MO
2005 St1300
8568
For those less knowledgeable, with a metric thread you subtract the pitch from the thread size to get the correct tap drill size.
Okay... me confused. What does pitch have to do with diameter of the tap hole? If it is a 1 or 1.5 pitch the thread depth is the same, no?
Newport News, VA
2006 ST1300A
Different thread pitches have different diameters to the roots of the threads, hence different starter-hole diameters for tapping. A 1mm pitch thread will have a more shallow thread than a 1.5mm pitch thread, thus it will require a larger starter-hole.
New Jersey
st1300 '04
7163
for a 14x1.5 thread the drill is 14-1.5 or 12.5mm
for a 14x2 thread the drill is 14-2 or 12mm
and so on.
pretty sure the 1300 is a std 14-1.5 thread.
sirepair
sirepair
Let's RIDE!
Chillicothe, Ohio
2003 ST1100P
7105
Ok, the plug has been repaired.
With the threads stripped from the previous plug, I was able to take the 1/2" drill bit and run it in the hole by hand; took out very little, if any material! Covered the end of the tap with bearing grease and carefully started it in the hole.
Once it bottomed out, I backed it out and noted a good bit of debris on the tap. Then I took several Q-tips, dipped in grease, and swabbed out more bits. Once I felt that I had all the bits cleaned out, I stuck the red nozzle of a can of carb cleaner up in the hole, past the debris, and emptied about 1/2 the can in there to backflush the hole.
I then took the new plug and installed it; I *think* it must be an oversized one (didn't say that on the package!) because it basically retapped the hole. I would turn it in a couple of turns, back it out and go some more.
I cleaned the hole again as above and ran the plug back in. I left the plug out for now to allow the carb cleaner to dry.
I think the repair will be ok. Threads look pretty good. I'll use a rubber washer and go easy on the torque.
970mike
Mike Brown
Lompoc, California
07 & 12 ST1300A
SPOT
LINK
8057
Great job on getting the threads redone. You may want to pour a little oil through the engine leaving the plug out to make sure all of the junk is out the crankcase. It would be cheap insurance.
sirepair
sirepair
Let's RIDE!
Chillicothe, Ohio
2003 ST1100P
7105
Sounds like you got er done Pat. I like Mike's idea about pouring some thin oil in to flush any crap out.
That was the purpose of the carb cleaner flush. By using the little red tube that comes with the cleaner, I put the tip in past the plug and let-er rip! I then took clean Q-tips and swabbed up what didn't drain back out.
I need to get a bore scope! Would have made inspecting the hole very easy!!
ReSTored
Mississauga, Ontario
2019 Tracer GT
4463
Sounds like you've got it sorted out. But any residual bits go thought the filter befored before being distributed out so you're covered both ways I think.
Grand Junction, Colo.
92 ST1100
One of the hard fiber washers for that application would have a better seal. Rubber doesn't like heat or petroleum products.
Donegal, Ireland.
Vstrom 650
[quote;1743615]That is a neat product but hanging under the bike could be an issue..[/quote]
I thought maybe with the forward facing drain bolt on the ST that it might work.
Firstpeke
NT1100D
UK
Honda NT1100
7764
That looks like an interesting idea!
Of course if it were fitted you would need to wirelock it closed, otherwise some charming little.... person... could come along and drain it for you.....
I'd be concerned about protection from corrosion and road grid... especially on the Britt isles though :lol:
