Add my bike to the LEAKS :(
Kevin_56
Montfort, Wisconsin
20 R1250RT
6495
But, I've not replaced every hose, just the larger ones (which are the leakers).
I have, and if the clamp screws are turned upwards or the ones attached to the wax idle unit, you will have to remove the throttle bodies to tighten all of the clamps. the smaller hose clamps do loosen up. A couple of mine were loose when I did fixed my leaking alternator o-ring repair.
Tdinova
Nova Scotia
'07STA
7235
Before I remove the throttle body I will remove the rad and catch as much antifreeze as possible. The antifreeze is 2 years old and I will reuse it if it is clean. I maybe able to see a leak or 2. I used the Honda Type 2 coolant from the Honda car STEALER. I have a small electric heater that will feel great in my garage.
Kevin_56
Montfort, Wisconsin
20 R1250RT
6495
Understood Kevin. Mine were all issues with the larger hoses.
BakerBoy - Wish they all were accessible from the front. Pulling the TB's is a pain, but to make sure, you are going to have to. Unless you want to roll the dice and go for the easy ones. You will have most of the steps completed to replace your coolant once the radiator is removed.
Kevin_56
Montfort, Wisconsin
20 R1250RT
6495
There was no rolling of the dice Kevin.
That was meant for the OP. As you are aware that "seeing" under the TB's is next to impossible. I even tried using a nice "bore scope" from The Dan.
The only way to see under there is to pull the TB's.
Cary, NC
ST1300, VT750C
I pulled the TBs on my ST twice and really, once you get access to them, the actual removal isn't much more trouble. For what it's worth, mine were stuck pretty good and I'm a little ashamed to say I popped them loose by levering a claw hammer between them and the frame while protecting the frame with a patch of leather. Who ever heard of working on a motorcycle with a claw hammer - uh that's me.
Claw hammers are very useful. I'd be willing to bet that if someone started a thread, "Whats the most unusual tool you used while working on your bike?" we would have some surprising responses.....
Tdinova
Nova Scotia
'07STA
7235
Made it back alive. I followed the manual step-by-step. It was A OK until I had to work on the throttle body.. I did a lot of thinking before I tackled it. Getting to the clamps on the rubber isulators was abit tricky but not that hard, trying to lift the throttle body off the isulators was nerve racking. After 15 minutes 'she popped'.
I never really found any 'There it is, THE leak' but small ones
Here is a picture of the water pipes with the mat pulled back. The temperature sensor was green. Is that normal or is that a leaking component?
I have 2 clamps on the top rad hose because the old clamp got broken when I changed the coolant 2 years ago. I think I will buy the correct one. another $12
I found the mysterious entrance to the square drain hole. It is located behind the thermostat facing the alternator
Not much mess. I caught 99% of the coolant. I will be throwing all of it out and starting with new. No rolling dice
I going to Mother Honda and order the line between the 2 fuel tanks and the clamps + I will replace the thermostat and O ring while I have it off. I removed all of the coolant line, scrubbed all the surfaces with scotch bright and go from there.
Pretty bare bone
Tdinova
Nova Scotia
'07STA
7235
Can I start my bike with the top gas tank off once I get all the parts on and refilled with anti-freeze? I am going to buy the extra tubing to extend my starter valve lines then syn the body with my mercury sticks.
BakerBoy
It's all small stuff.
Golden, Colorado
1408
Yes, it will start and run (as long as there's fuel remaining in the lower tank). It may produce a 'failure' code given that the IAT (inlet air tempertature) sensor is disconnected. The IAT resides on the air box cover, towards the rear.
Tdinova
Nova Scotia
'07STA
7235
Yes, it will start and run (as long as there's fuel remaining in the lower tank). It may produce a 'failure' code given that the IAT (inlet air temperature) sensor is disconnected. The IAT resides on the air box cover, towards the rear.
I just remembered the unused gas gets pumped back into the top gas, SO I would say NO , because it will make one hell of a fire/mess.
Tdinova
Nova Scotia
'07STA
7235
Ok all is going well. Went to Mother Honda and ordered my parts, should be here tomorrow.
I done a lot of running around today to find the Tygon 5/32 tubing. I found it at the local hobby shop. 2 packs 3 feet each. I had 8 inches left.
1st start.
upside down
finished
I will have to buy a spare T JOINT, FIVE-WAY 17201-MCJ-003 , it feels like it could break by going BOO
I have removed and replaced ALL the coolant hoses on many ST's and have never needed to remove the TB once.
It can be done from the front with the correct tools.
.02
Tdinova
Nova Scotia
'07STA
7235
.02
I took mine off to tighten the hoses under the throttle body. I was nosy anyway. It's winter time.
Kevin_56
Montfort, Wisconsin
20 R1250RT
6495
.02
Well Larry - For those of us without these "special" tools, you have to remove the TB's to remove and replace some of the hoses. No other way around it.
