ST1300, 2006, was running fine, have about 55,000 miles. Go out this morning, turn the key, so far so good. Hit the button and all it does is gives off a high pitch steady whine and will not crank the engine. Once after holding the ignition button in for about 5 seconds I get one pop out of the exhaust like it wanted to turn.
I check the battery under load, still in the 11.5 range. Pull the plugs, don't look too bad, but replaced them anyway. Pulled the battery anyway and took it to a local cycle shop buddy, checked it on his load tester, battery is fine.
I did some searching here and came up with checking the ECM codes. But the directions say the ECM plug is accessed under the seat. On my bike it looks like I need to take the rear cowel off to get to the ECM, is there an easier way? Also, the F1 light does what it normally does, goes on then shuts off.
Weird it was running fine, put a couple hundred miles on during the past week, then it sat for about 2 days before this happened.
Are there any known issues with the ST1300 that I should be looking for? Any help would be appreciated. Luckily I still have my Shadow, so there is a reason for having more than one motorcycle. Thanks.
