QUOTE="Upt' North, post: 2242619, member: 40759"
Good work Captain.
Just to help us lesser mortals, I'd love to know.....
How often in miles and months/years do you change tyres? Never tried a tyre, always had tires
, when they are worn sufficiently. Depends on the tire since I've ran a car tire since 6?,000 miles.
Do you re apply at each change? At least some Yes. On car tires I've even dropped the wheel down from the hub to reapply some before a long vacation trip midlife of the tire. Remember my normal car tire change interval is over 40,000 miles. This spline lube went 46,850.
Do you clean the old off at change time? usually most of it but not always all of it.
How do you apply? With a small brush. Toothbrush yesterday.
How much do you apply? It's pretty much "covered". Maybe a .050" thickness all over the wheel spline. Sometimes dab it on the hub splines. Some under the hub as I remove the entire hub (pull the circlip out) to check bearings individually and the bottom oring.
If you clean the paste off at change time, how do you do it? Gasoline!
Do you change the O rings? Not always, maybe every 80,000.
Sorry for all the questions but those splines are like new and your routine seems to be the one to follow rather than the alternative of guessing. I'm all about guessing.
Also riding style would be interesting. Most of those miles have been with the cruise control set to 82 mph (or higher (really)). Start at daybreak and quit after dark
. I rode 1090 or so back from Locstoc in a good long day just last month. Found the data: (1096 miles in 15 hours 17 minutes for an average speed of 71.72)
Ta in advance.
Upt'North.
/QUOTE
I replaced the flange bearings once. They were dust bits. The rear wheel bearings are original.
