Guys, He is in Russia. So, all the pumps everyone is showing more than likely are not available there. But, he is getting the idea! Stick with a 12volt pump.
Visited the site. Liked what I saw. Looking forward to supporting my former, fellow New Yorkers.Go to motopumps.com
Built and sold by a rider in New York.
Made in USA.
Wow that's tiny. The question of any air pump (even tiny ones bigger than yours) is reliability. I hope that lasts a long time.Finally, I've got my new air pump.
I have a Baseus|InAuto inflater my friend found on a Ural sight very nice for sale on amazon lithium battery screw on hose that looses no air upon removal real dealWow that's tiny. The question of any air pump (even tiny ones bigger than yours) is reliability. I hope that lasts a long time.
The quick release chucks don't really appeal to me. Some are incredibly stiff to operate with a squared edge on the lever. I've found just over filling a tire by a pound or two allows me to unscrew the connecter without losing more than a half to one pound of air. As I'm not a Track Gui a pound more or less (if that much) isn't a big deal.
I admit if the hose is stiff then getting the valve started in cramped quarters can be more fun than I like. But once it's on — it's on!
that thing i've got is Baseus too) feels sturdy and solid, has a metal casing. Checked pressure indicator too, no big difference from the measurements of the car inflator.I have a Baseus|InAuto inflater
Exactly what I have used , for years. saved my butt more times than I can remember. The only failure I have had with these is the plastic lever on the valve fitting broke on me in the middle of Durango, CO. Luckily, there was an air station nearby.CO2 is a one shot deal but a compressor works as long as 12 volt is available. If space is tight you can remove the air pump from the plastic case to minimize it's size. You might have to fabricate a protective cover or guard over the electric motor's gear wheel for safety and so it can be held or laid on the ground. I took a piece of plastic from a large pill bottle and used it to cover the gear wheel and pump cylinder. The pump cylinder gets hot but can be held by the plastic cover zip tied to the pump. This pump is 9 years old and has been used many times on the road. Once it set the bead on my ST1300's rear wheel. It started life as a Slime pump in a plastic case.
My BMW has a perfect space under the luggage rack for a pump and tools but it wouldn't fit everything if the pump was in the original case. I pack the pump and power cord wrapped in a cloth then place it in a padded plastic bag. The ST has a similar space in the tail section.
I just looked at the Baseus Inflator and it looks to be a great little unit. I'll take a no-loss screw On/Off valve over quick release any day. I've had a problem with a couple quick release valves in the cramped confines of the rim-rotor continuum. This Baseus is pretty reasonably priced as well. Thanks for its mention.that thing i've got is Baseus too) feels sturdy and solid, has a metal casing. Checked pressure indicator too, no big difference from the measurements of the car inflator.
Decided not to bother with quick release hose, hope I will not use it very often)
And you'll have a much better chance at re-sealing the bead than with a slow filling pump motor.Something like this, with a hand full of the CO2 cartridges (they come in different sizes). No electricity needed, and minimal chance of failure (like blown fuses and such).
You can find charts for recommended # of cartridges for various tire and cartridge sizes.
Wear gloves when using, cause the bottle will get REALLY cold during discharge.
I raised this question with exactly this idea in mind. But I was told that Co2 inflator will be not very practical for pumping relatively big ST tire.Something like this, with a hand full of the CO2 cartridges
2 CO2 cartridges will fill the rear tire enough to get you to the next gas station. The big advantage is that each cartridge will empty into the tire with explosive force which will seat the tire bead which is almost impossible with 12 V compressor. 2 cartridges take up no room and may save your butt one day.I raised this question with exactly this idea in mind. But I was told that Co2 inflator will be not very practical for pumping relatively big ST tire.
Anyway, I've got very small battery powered pump and I hope it will do what it supposed to do)
I thought it was too! But, when the battery wears out it wont hold a charge, as i discovered last tour. Without a doubt, i was one pissed off guy when it took me half an hour to check my tires, because I had to keep recharging it. It is heavy too!This is a great pump, has an internal lithium battery no need to fiddles with plugging into a power supply.
