Does anyone have actual PERSONAL DATA regarding the 1300 and non-ethanol as regards recorded gas mileage?
Many of the posters here ride the ST1100, if I'm not mistaken.
I would anticipate better fuel economy, but have no proof.
I can buy regular and premium "pure gas" at Bucc-ees, but it would take almost a gallon of fuel to get there.
TIA.
Mileage is a very slippery beaste. Regardless of how hard we try, there are too many variables in everyday life. First of all, do we fill the tank to the exact same point, using the same pump? How accurate are the pumps, and what about the quart to half a gallon that we pump that is the gas pumped by the previous customer? Your mileage will be affected by your route, speed, winds, hills, etc.
I try to keep every receipt for gas that goes into my bikes (and cars) and I enter the info on an Excel spread sheet. Despite trying to be as accurate as possible, my mileage varied somewhat from year to year. I think I was riding faster on freeways for the last three years, but otherwise cannot explain the difference. I regularly alternated between 91 and 87 octane to try to average what Honda wanted, and usually filled up at half a tank.
Here is my data by year, and the miles were distance covered that year:
2014 4681 mi 44.54 mpg
2015 3408 42.15
2016 4216 39.90
2017 5081 39.72
2018 5056 39.60
Based on my experience with my ST, and the fact that my VStrom's numbers similarly vary, I think that picking up a difference of a few percent by using gasahol vs gasoline would be extremely difficult.
If you wanted to do the test, one would have to control for as many variables as possible. For example, you could yank the fuel tank and hang a fuel bottle next to the bike, which is strapped to a dyno, carefully measure the fuel that goes in the bottle, verify the accuracy of the rear tire's circumference, record ambient conditions, and run the bike on the dyno for several carefully programmed accelerations, decels, maybe even stops, or a steady 60mph. Then repeat for your other fuel. This would eliminate wind resistance, but would give a baseline improvement (either pos or neg) using 100% gas. It's probably not going to happen.
