Well, after a couple of thousand miles and PASTOC, I am certainly loving my '07 FJR. Great review, Rick, very objective. I was never a Metzeler fan with other bikes, but after experiencing the Z6's, I am a full convert. Supposed to be the best wet and dry tire, and I will put the Interacts on when these go. Unbelievable confidence and this bike can be flicked around very nicely. The weight and COG factor are its biggest selling points. I would have thought lighter would have meant a feeling of less planted, but it's the opposite.
The suspension is 3-way adjustable on the front and 2-way on the back. So many combinations, and I am still tweaking to suit me. I think I have it a bit firm at the moment, but I will say, this bike sure soaks up bumps very well.
The seating position and forward pressing on the bars takes some getting used to, and I think Yamaha actually did quite a bit of engineering on this. The seat could be made perfect with a little more width, flatness and firmness. I am going to try a Corbin here shortly.
Heated grips come standard on Canadian FJR's. The adjustable fairings for heat (out for warmer) don't do much in my brief test. Once you get moving over 50-60 mph, the heat isn't there. However, if you want to warm up, just stop and leave the engine running for three minutes, as soon as you start moving the accumulated heat in the fairings nicely warms up your legs from the knees down, for a few minutes, then it's all dissipated. Way less heat than my ST1300 from my memory.
Crash protection - I have installed rear sliders from Belgium, and have a set of front crash bars coming from Racing905. They have rear ones also but they are fugly. This will give protection comparable to the ST1300, especially if you put a small slider on the front bars.
I am in the process of installing a dash shelf to mount the GPS, TPM and heated gear controllers, so this can be a serious ST machine.
I think Yamaha did a nice job of the GenII FJR's and what's not to like? I agree about the fuel injection surging at low rpms, and so far moving up to 89 octane has fixed all of that. There was no ECU change for my bike, although I'm not sure about the ones out west in the mountains......
Oh, did I mention if you haven't found the afterburner switch, just crank it over 6000 rpm in third. Whoa!!!!!!!!!!!!!!
And Pete, you are right about this forum, absolutely the best!!!
