I am using a Hankook CT on the back of my ST-1300 and would like to run a 130/70-18 Battleax BT45 on the front. I am running the BT45s on the front of both my 1800 and 1500 Gold Wings and the tires handle fine and are wearing very well.
++++++++++++++++++++++I am using a Hankook CT on the back of my ST-1300 and would like to run a 130/70-18 Battleax BT45 on the front. I am running the BT45s on the front of both my 1800 and 1500 Gold Wings and the tires handle fine and are wearing very well.
Thanks for starting this thread. I've given it some thought too. A fellow member (ag5i) is also using the BT-45 on the front of his GL1800. Last time I saw him, in November, he had 13,000 miles on it and it looked brand new. No cupping or uneven wear. I'm sure the 709 is a good tire too but the lack of tread/sipes gives me pause.I am using a Hankook CT on the back of my ST-1300 and would like to run a 130/70-18 Battleax BT45 on the front. I am running the BT45s on the front of both my 1800 and 1500 Gold Wings and the tires handle fine and are wearing very well.
Does this include US registered bikes visiting Canada?++++++++++++++++++++++
Also up here in Canada the Highway Traffic Act clearly states any Vehicle running both Bias Ply and Radial Ply Tires at same time is subject to a $1,600 Dollar fine and immediately towed.
Ron
I'm running the G709 front with a London Taxi Tar dark side on the rear.The Bridgestone G709 130/70-18 is a better Tire for cornering and never cups. Also up here in Canada the Highway Traffic Act clearly states any Vehicle running both Bias Ply and Radial Ply Tires at same time is subject to a $1,600 Dollar fine and immediately towed.
Ron
That is insane! There is NO valid reason you can't mix radial and bias ply tires on a motorcycle!Also up here in Canada the Highway Traffic Act clearly states any Vehicle running both Bias Ply and Radial Ply Tires at same time is subject to a $1,600 Dollar fine and immediately towed.
You got a link to that regulation??++++++++++++++++++++++
Ron
====================You got a link to that regulation??
That may be the law, but I seriously doubt many LEO's would think to check a motorcyclist's tires during a traffic stop.++++++++++++++++++++++
Ron
Any idea why the recommendation for the new tires on the rear? Discount Tires follows that mantra and I had to fight them to install a new set on the front on my front wheel drive.Hmm, well, I did find this in the Ontario Driver's Handbook. http://www.mto.gov.on.ca/english/dandv/driver/handbook/section5.1.4.shtml[/url And then this from the Goodyear Ca website [url]http://www.goodyear.ca/faqs/technical/ If the tire company has posted this, then it'll be the law - they are really scared of lawsuits/legislation. So I'd say you'd be safe with Radial rear and bias front for a bike.
"When radial tires are used with bias or bias belted tires on the same car, the radials must always be placed on the rear axle. Never mix radial and bias-ply tires on the same axle. When you select a pair of replacement tires in the same size and construction as those on the car, we recommend you put them on the rear axle. A single new tire should be paired on the rear axle with the tire having the most tread depth of the other three. "
Ooh, I"ll give you a real-life example (I always wondered about that myself). I found out the interesting way (which is a few degrees better than "the hard way") that when you have good tires in front and bad tires in back and you hit slickery stuff in a corner and let off the gas that the front end with traction slows down and the back end without traction slides out and passes the front end. whoooO!!! Once you figure that out, it's actually fun, but that first time or 2 it's a puckerer, with inexperienced drivers it would be not so good. If the front tires are worn and the rears are good, then you already tend to enter the corner slower and the back end stays in line with the front. The front may "push" or slide a bit, but the back will not do anything unpredictable. Worn front tires basically just exacerbate the inherent "pushiness" or understeer of front wheel drive, easier to handle than unpredictable snap-oversteer, which is what I experienced.Any idea why the recommendation for the new tires on the rear? Discount Tires follows that mantra and I had to fight them to install a new set on the front on my front wheel drive.
