Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Help...milky substance in oil level sight glass!
  1. #1
    KarmaDog's Avatar
    ST1300A 2006
    Join Date
    Jul 2009
    Duluth, MN
    Posts
    443
    My Gallery
    Well, I pulled my motorcycle out of winter storage to change the oil, and everything looked fine. I started it up after a whole winter of sitting in the garage, and after a few minutes I shut it down and looked at the sight glass and saw some whispy white material just above the oil...Yikes! Well, I looked at the radiator overflow bottle and everything is between the lines as it should be.
    I drained the oil (no milky oil...actually very clear and clean), I replaced the filter, refilled the oil with Rottella T6, and still some milky whisps in the sight glass....so I hoped on, and took it down the street for a 10 minute ride, temp rose to right level and remained there. When I got back, I let the bike sit the appropriate time, looked at the sight glass and everything looked fine, no more milky stuff. WHAT GIVES?
    Do I have to worry...what should I look for? Cheers, and thanks for any suggestions or comments. Brad in Duluth
    KarmaKruser
  2. #2
    bcst1300's Avatar
    sold dec 31 14
    Join Date
    Dec 2004
    Victoria
    Posts
    266
    Tip Overs
    4
    My Gallery
    Re: Help...milky substance in oil level sight glass!
    Maybe a very small amount of water from condensation?
  3. #3
    Unterbrecher von Sachen BakerBoy's Avatar
    2016 R1200RT
    Join Date
    Jan 2008
    Golden, Colorado
    Posts
    6,854
    My SPOT
    My Gallery
    The new oil that had white whispy stuff floating on it... have you looked at it again now that it is drained to see if anything settled out of it or rose to the top? (My guess is no, but just worth a check.)
    John - 2016 BMW R1200RT
    "Sometimes you find yourself in the middle of nowhere,
    and sometimes in the middle of nowhere, you find yourself." ~Unknown
  4. #4
    Dump the 5-40 synthetic oil and refill it with some Mobil Delvac 1300 or Valvoline Premium blue 15-40. They will clean the engine out much better than the T6 IMHO.
    The Dino HDEO's suspend stuff better. .02
  5. #5
    Ventura Highway wjbertrand's Avatar
    Join Date
    Feb 2005
    Ventura, CA
    Posts
    4,627
    My Gallery
    Sounds like you put it away with used oil in it and changed it later when you took it back out? That's backwards if so. The used oil will have moisture in it that probably caused a little emulsification while sitting. It's better to put fresh oil in and then store
    the bike.
  6. #6
    ST090's Avatar
    2014 FJR 1300A
    Join Date
    Dec 2004
    Green Valley, AZ
    Posts
    165
    My Gallery
    I concur with the condesation and leaving used oil in for the winter.
    John L. Wilson
    Green Valley, AZ
    STOC 090
    IBA 16288
  7. #7
    Quote Originally Posted by ST090 View Post
    I'm thinking your clutch and brake fluid should probably be flushed too
  8. #8
    (Threadstarter)
    KarmaDog's Avatar
    ST1300A 2006
    Join Date
    Jul 2009
    Duluth, MN
    Posts
    443
    My Gallery
    Quote Originally Posted by wjbertrand View Post
    the bike.
    Oops....Yes, it was backwards. I have learned a valuable lesson. It was just me being lazy and riding to the very last minute (so that it was so cold that I didn't want to work on my bike in an unheated garage!). I really appreciate the feedback.
    I checked the sight glass this morning and everything looked fine after sitting for the night (no milky clouds of any kind). It must have been a small amount of moisture in the oil as noted above...thanks everyone for their comments and advise....the PEOPLE and the SITE absolutely ROCK!!!!
    Cheers, Brad
  9. #9
    (Threadstarter)
    KarmaDog's Avatar
    ST1300A 2006
    Join Date
    Jul 2009
    Duluth, MN
    Posts
    443
    My Gallery
    Follow-up question: It is correct to wait until spring (pulling bike out of storage) before changing clutch and brake fluid? My understanding is they actually collect moisture during winter storage. So, it looks like one can't really do ALL the fluids at once in the Fall (or am I wrong again)
  10. #10
    Tom Padden TPadden's Avatar
    Join Date
    Apr 2006
    Brooksville, FL
    Posts
    2,610
    My Gallery
    Quote Originally Posted by Igofar View Post
    ... and I'm thinking you should just ride the damn thing. Once engine temps reach about 190 degrees for a while the H2O will evaporate.
+ New Posts
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
