Mountain Mike
I frequent the IBA Motel
All credit goes to Fred W and this thread in the Zumo forums.
"Yes exactly so. It's just a steel wire cable that will slow down a thief from just unscrewing the ram arm and making off with the whole kit and kaboodle.
So, here is my revision 1 to the locking idea in post #1.
I made a small alloy slider with a right angle on the top to hold the release mechanism from popping up, either via thieves or a big bump in the road.
Here's the new slider bar
Reassembled the cradle mount with some strategically placed washers to provide the slot for the slider bar to slide up and down in.
http://i916.photobucket.com/albums/ad4/FJWinNH/2004%20Man-Strom/100_3085.jpg
Now when the little padlock is looped through the lock holes it still prevents the release button from being pressed in, and the slider bar prevents the spring loaded release mechanism from popping up under any circumstances.
Disclaimer:
I know that an industrious thief could probably pry up the aluminum plate and then somehow yank the GPS off its mount. I know that it is safe to stick the GPS in your pocket when it will be out of your sight for more than a few moments.
Template: http://home.comcast.net/~FJR-NERDS/Files/Zumo_6XX_Lock_Template.pdf
Disclaimer:
