Need some help! Trouble on the road.
Minnesota
2012 ST 1300
003323
8560
I took off today for Indiana. First 350 miles the bike ran fine. Then I started getting a "hiccup" in the bike. At first it seemed to happen mostly around semis so I attributed it to the wind vortex. Later it got worse, more frequent and not around trucks, like a miss, or the bike trying to seize or something. I pulled off the slab in Terre Haute and put fresh fuel in the bike in case I had bought some bad gas. I also dumped in a can of water remover/injector cleaner. Started it up -- Cured! Take off down the road and 40 miles later the same problem is back. I stop, turn off the bike, open the gas cap, put the gas cap back on, turn the bike on -- Cured! Take off, run 25 miles and the problem is back. Turn the bike off and immediately back on -- it doesn't fix it. Turn it off, count to 10, turn it back on -- Cured! So I'm thinking I have crap in the fuel filter. Does anyone agree or does someone have a better diagnosis? Second question, where the heck is the fuel filter and how do I get to it?
Stuck in Indiana.
Bob
ScubaDave
NH
st 1300
7998
Sounds like you could have a plugged or kinked vent line on the gas tank.
Kingman, Arizona
2000 ST1100 ABS TCS
004
Fuel pump? (Folks here know why I'm bringing this up, tho I know next to nothing about the 1300 fuel system, it's become more common on 1100s in recent days. :D)
Keep us poSTed. Anyone close?
skidlid1300
Blacksheep Tribal Member
In the woods
Schwinn
:plus1:Have you replaced your air filter recently? I know you got to be careful on not kinking the vent line on the upper tank when lowering the tank back down.... It happen to me a while ago...
Raj_Zin
AKA Steve
Michigan
FJR1300A
6371
ChucksKLRST
Team Colorado
Aurora, Colorado
2019 Versys 1K SE LT
086
The dealer replaced the air filter recently. Where does this vent line run?
Lift the top tank you will see it attached to the underside of the tank. Follow the proceedure in your service manual. Easy to do. Takes about 10 min to check the vent line.
jodog
Minnesota
2012 ST 1300
003323
8560
I read the other threads. When I left the temp was 68. When it started acting badly the temp was about 86. When it lasted only 25 miles the temp was 91. Should I try to replace the fuel filter or do the pump at the same time. I'm betting this is not an item typically in stock.
BakerBoy
It's all small stuff.
Golden, Colorado
1408
Correct, not likely in stock at any dealer...the few pumps in the US seem to be at distribution centers. A couple years ago, you could buy just the fuel pump. But now when you wont a fuel pump, you have to buy the whole fuel pump assembly (not just the fuel pump) from Honda unless you go with a pump made for Honda cars (some have done that).
I'll post in a few minutes the hoses you need to look at for kinks Bob.
BakerBoy
Golden, Colorado
1408
I wonder about a fuel pump... several of us have struggled with it. But you should look for other simpler explanations first. If it is a fuel pump or kinked line, it won't likely strand you but will give you some erratic engine behavior.
Below are the fuel hoses ...they're rearward under the tank. This picture is taken from near the windshield with the upper tank tipped up.
You can see some of these hoses by removing the front seat--inspect them by removing the seat before tipping the tank.
Look for kinked, collapsed, or pinched hoses.
Connection 1 is an air vent between upper and lower tanks.
Connection 4 is the main fuel feed from the upper tank to the lower tank when fueling the bike.
Connection 2 is the water/fuel drain from the dirty space under the gas cap, exterior to the filler neck on the tank. (It drains fuel spills or rain water)
Connection 3 is a scavenger line to the charcoal canister. Make sure it is not full of fuel or you'll vacuum lock the tank.
Connection A is electrical; it has the fuel level sensor wiring. (Note, I errantly placed the "A" on a hose and not on the wiring. The wiring is actually hidden behind the hose.)
(Anyone, please correct me or add to the info, thanks.)
000540
Since the dealer just replace the air filter... chances are the hoses are the issue or even the sensor on the back/top of the air box is not plugged in very well. If it's the fuel pump that would not be fun but is a possibility.
Sounds like vapor lock of some kind.
When you open the cap, or wait, then it works, it sounds like a vapor lock.
Since the dealer was under the hood (fuel tank), My money is on a pinched or kinked hose
from when the tank was lowered.
Hope is this easy for you.
Good luck.
zooker13
Ken Zook
simi valley ca.
05 ST1300
7960
Number 2 is the vent that goes to the canister on the right side. You could unplug it from the tank and try it.
drrod
Calgary, Alberta
'04 ST1300
8313
Try riding with the fuel tank cap unlocked and cracked open. If that cures the problem, then virutally certain the vent line is kinked or plugged.
Rod
Kingman, Arizona
2000 ST1100 ABS TCS
004
Kreis Weigel (h2orider) has just mentioned lots of the suspected fuel pressure regulators 'n such have turned out to be fuel pumps. Might check in with him for more details.
