Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Site Supporter RealST's Avatar
    2007 ST1300A
    Join Date
    Sep 2009
    Poultney, VT
    Posts
    2,701
    Tip Overs:
    2
    My SPOT
    My Gallery
    Harbor Freight Motorcycle Lift
    Got my lift at 9pm last night. Paid $299 for the lift and got 20% off the wheel chock. (THANKS to those that sent me the coupons!)
    Got it back to the office at 10pm and worked till 2:30am setting it all up. Still have a few more mods to do (Tie Down points and a rubber pad for the center stand. I'll also be adding a hook in the ceiling to lift the rear so I can set it on the center stand after its in the wheel chock.)
    Here she is!
    ON THE LIFT!
    I used the Harbor Freight Wheel Chock#96349. Then I took it apart. Mounted it directly to the lift table. Cut off the tabs on the bottom plate and used it as a backing plate to mount the top into. Will post details below.
    Up close, you can see that once you move the arm in the back to the lowest setting, it works perfectly with Larry's STuff STopper.
    I can't get a full lift out of it because I hit the ceiling. If need be, I can pull the wind screen and get it all the way up.
    Sent from my DROID X2 using Tapatalk 2
    Larry Jensen
    ...gone sailing
    2007 ST1300a For Sale Click Here
    SportTouringGear.com Click Here
  2. #2
    Team Colorado ChucksKLRST's Avatar
    2003 ST1300A
    Join Date
    Dec 2004
    Aurora, Colorado
    Posts
    4,842
    Tip Overs:
    1
    2013 Miles:
    006154
    My SPOT
    My Gallery
    Re: Harbor Freight Motorcycle Lift
    Just looking at your pictures, You are going to want to give yourself more room on the right (starboard) side of the lift. Also might want to make out rigger boxes (for your feet) to be able to ride the bike up on the lift easy. As a note: I do not use the wheel chock, as I find it gets in the way of some maint. procedures, such as taking the front wheel off, turning the bars, etc. Do what works for you. Make sure you ALWAYS USE THE SAFTY BAR. Never let just the jack hold the weight.
    What is your garage floor finished with?
    Attached Thumbnails Attached Thumbnails IMGP0456.jpg   resizeIMGP0460.jpg   resizeIMGP0450.jpg   IMGP0449.jpg
    Chuck Henderson (US Army RET 1968-1991) (Forever Home – Colorado) STOC# 086, KLRST# 001
    RIDE a little FASTER, RIDE a little FURTHER
    03 ST1300 ABS (Silver STorm) 09 DL650 ABS (Weezer)
    10 ST700 (Now & Then) 08 DR650 The LiST
  3. #3
    Site Supporter azlife4me's Avatar
    '07 ST1300A
    Join Date
    Nov 2007
    Posts
    1,137
    My Gallery
    Nice job, Larry. Thanks for sharing the photos.
    Tom
    Happily retired
    '07 ST1300A
  4. #4
    (Threadstarter)
    RealST's Avatar
    2007 ST1300A
    Join Date
    Sep 2009
    Poultney, VT
    Posts
    2,701
    Tip Overs:
    2
    My SPOT
    My Gallery
    Chuck, I don't have room to move it over unless I'm working on that side.
    As for the floor. Carpet...she's actually in my office!
    Unigo Trailer is hiding in there too.
    Larry Jensen
    ...gone sailing
  5. #5
    (Threadstarter)
    RealST's Avatar
    2007 ST1300A
    Join Date
    Sep 2009
    Poultney, VT
    Posts
    2,701
    Tip Overs:
    2
    My SPOT
    My Gallery
    Details on the Mod to the chock.
    I removed the chock from the bottom plate.
    Using the bottom plate as a template, I marked and then drilled the mounting hole locations for the chock (not the plate mounting holes!)
    I cut the two "ears" off the back of the plate to allow it to fit under the bar on the lift table. Repainted and put in place.
    Now using the same bolts that came with it, I reassembled it and dropped the rear arm to the bottom hole.
    Larry Jensen
    ...gone sailing
  6. #6
    Smaller, lighter package Smash's Avatar
    2006 Ninja 650R
    Join Date
    Mar 2009
    Wheat Ridge, CO
    Posts
    9,605
    2013 Miles:
    004427
    My SPOT
    My Gallery
    NICE.
    I have a friend with one of these. He's had it for years and it's seen a lot of use. He got the same chock you're using too. Man, I love that thing. I've worked on his bike, other peoples' bikes and even my own bikes on his lift. It's on my purchase list for someday.
    2006 Ninja 650R "DLW" - his
    2000 ZR7 "Blue" - hers
    1994 ST11 "Kita" - RIP, 1988 C10 "Jesse" - RIP, 2001 Shadow Sabre - Sold, 1995 Vulcan 750 - Sold
    http://smashrides.blogspot.com/
  7. #7
    2003 ST1300A
    Join Date
    Dec 2004
    Aurora, Colorado
    Posts
    4,842
    Tip Overs:
    1
    2013 Miles:
    006154
    My SPOT
    My Gallery
    Quote Originally Posted by RealST View Post
    And I thought I had space issues. Must be hell getting the bike around the corner with the desks there.
    Here is a small mod I made for the safety bar storage. It is alway handy, I don't have to go look for it and it is always on the correct side of the lift.
  8. #8
    Mark Kunath/ST 1800 Bigmak96's Avatar
    04 GL 1800
    Join Date
    Jul 2008
    Shakopee Mn
    Posts
    4,649
    Tip Overs:
    100
    My SPOT
    My Gallery
    I like your bar storage Chuck. i have left the chock on mine and it serves as a good place to park the one wheel trailer.
    STOC # 7910
    IBA#55039
    ST 1800
    Click "My Photos" to view
  9. #9
    (Threadstarter)
    RealST's Avatar
    2007 ST1300A
    Join Date
    Sep 2009
    Poultney, VT
    Posts
    2,701
    Tip Overs:
    2
    My SPOT
    My Gallery
    Chuck, I like that idea! Thanks.
    It is tough and had tried a skate board on the carpet, but no go. I use some moving men pads. Throw it up on the center stand on the moving men and then spin the bike into position.
    I am real close to turning this office space into my entire shop. If I don't some agent in those desks in the next few moths, out they go and I'll take over that area for the shop.
    Larry Jensen
    ...gone sailing
  10. #10
    scotschult's Avatar
    Join Date
    Nov 2009
    Fountain, CO
    Posts
    158
    2013 Miles:
    000991
    My SPOT
    My Gallery
    Quote Originally Posted by ChucksKLRST View Post
    Here is a small mod I made for the safety bar storage. It is alway handy, I don't have to go look for it and it is away on the correct side of the lift.
    Attached Thumbnails[URL="http://www.st-owners.com/forums/attachment.php?attachmentid=117279&d=1335545496"]
    Thanks for that Chuck! I've been wondering what to do with mine.
    Scott
    1980 GS 850G
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
