OK gurus,
I have an intermittent ABS light flash at me on my 05 1300. When I pull the code it is a 5 which says the rear module. I suspect a loose connection as it only happens when I hit a bump or when I ride in the wet. Some where in my short memory there was talk of some poor connection being common. Now I checked the sensor, seems fine, pulled the tail off the bike to get at the ECU and checked there for sensor resistance, can't find a spec but it seems about right, any one have the correct spec?. Connector looked great, power, ground etc are good. What I would like to know is how the heck do you get to the module connectors with out ripping the inner fender out of the way. And where is the connector for the sensor it's self, I don't really what to rip the front plastic again, getting lazy I guess. Seems I am working on this bike more than riding it. I think it sat too long in a comfy garage and is now complaining about how I ride it. ) The manual goes on to say swap modules front to rear to see what happens. ***, I really don't want to go there.
Thanks
Brian
Canoe B.C.
Thanks
Brian
Canoe B.C.
