2 Days ago I was doing my first Oil/Filter change on my 2001 ST1100. When putting the plug back in, I set my torque wrench too high (not wearing my reading glasses when getting the # from my Clymer manual), and cracked my oil pan at the plug hole. It was a low moment and I know how careless/stupid it was. I deserve any ridicule directed my way. Pics of the damage attached.
I want a permanent fix, so I am tackling replacing the oil pan. I have researched this extensively and found surprisingly little information (further evidence that I am one in a million).
If the exhaust was not in the way, the pan would just drop, but the inner exhaust pipes obstruct that from happening. I have reviewed the posts on alternator upgrade since they involve removing the pan, but I am wondering if it is possible to more simply: 1. remove the right side exhaust 2. remove the left side from the exhaust ports 3. remove the center bolt after the collector box 4. leave the bolts on the mufflers loosely attached as a pivot point 5. carefully pivot the left exhaust down far enough to allow clearance for the pan to be lowered and removed. With the exhaust aging and surface rust at the joints, I would prefer to remove as little as possible.
The pan screws will disengage with the exhaust in place as is and it appears the pan only needs a little clearance to come off.
Any thoughts (including criticisms) are welcome. Nobody can beat me up more than I have myself in the last 2 days.
Thanks.
Jim
Thanks.
Jim
