TPMS - Which One??
Millgrove, ON, Canada
2016 Versys 1000
6627
A major point in favor of the Doran is the ability to *add* the sensor to an existing valve stem. This looks like I could install the right-angle valve stems and add TPMS sensor. I like that a lot! If Orange used or could be used with those valve stems, that would tip the scale.
In my case, I did prefer externally mounted sensors simply for the convenience of replacement. First, you need to have metal valve stems, then determine if you have room to clear the brake calipers. On the FJR, there is no room on the front for an external mount regardless of valve stem. If you mount the Doran internally you need to use their threaded valve stem, 90 or straight come with the set. Orange is internal, not a deal breaker IMHO. On all the sensor batteries will die eventually and it's a matter of inconvenience when you want to replace the sensor, as you have to at minimum break the tire bead. Again not a deal breaker, it's same on automotive TPMS.
I also prefer 90 degree valve stems, however, before I had them I made up an air chuck out of fittings commonly available at your hardware store and could inflate the straight valve stems a lot easier. On the road, more of a PITA to connect most portable compressors.
Valve stem adapters one could use for filling..... again a matter of convenience....... http://www.amazon.com/Pacific-Dualies-18090-Degree-Extension/dp/B002L9J0VI
Lake Havasu City, AZ
2003 ST1300
8677
I just use the screw-on sensors that are PSI-specific. A glance shows me they are green when full, the yellow band shows when starting to get low, and then the red starts to show. Whenever I put a new set on, I check them a few times to make sure all is well and they aren't defective. Haven't had a problem yet. You can order exactly what you need. I have 42's on the ST and a 36 on the front of my Magna and a 40 on the rear.http://www.ebay.com/itm/26-80psi-TPMS-Tire-Pressure-Monitor-Valve-Stem-Cap-Tyre-Sensor-Indicator-Variant-/271010516122?pt=LH_DefaultDomain_0&var=570099725433&hash=item3f197c4c9a
I did not know that. I've got the "90 degree" valve stems from Mani (waiting for on opportunity to install them) so that's out. I've got a hose that screws on to the stem when it's time to top off the tires. But I have to over fill a little since some are is lost putting it on and taking it off.
I *like* those! I had some similar stems in plastic for my cars, years ago. I want to get my hands on a pair of 42s. Thanks for the link!
SteveST1300
Vendor
Ledgewood, NJ 07852
03&04 ST1300
5079
I just found this TPMS I have ordered one and it should be here in a few days it gives PSI as well as tire temp. it uses external sensors. I also ordered the hard wire kit for it. if you odrder direct from the co $189 $219 if ordered from Amazon. Look under products for the motorcycle unit.
http://api.viglink.com/api/click?format=go&key=43600dbd4d29bf22b89bb438534c545e&loc=http://www.st-owners.com/forums/showthread.php?125048-TireSafeGuard-TPMS&v=1&libid=1360069170711&out=http://www.tiresafeguard.com/&ref=http://www.st-owners.com/forums/forumdisplay.php?502-TPMS&title=TireSafeGuard TPMS&txt=http://www.tiresafeguard.com/&jsonp=vglnk_jsonp_13600691725462
New Jersey
st1300 '04
7163
Let us know how it works Steve.
fwiw one of the photo's on the $219 amazon page shows the $189 special ?
SteveST1300
Vendor
Ledgewood, NJ 07852
03&04 ST1300
5079
Thats right Carl and when I called I asked the guy which price I would get he said if you buy from them direct using the 818 phone number the price is $189 I paid $204 for the TPMS and the hard wire kit and shipping.
T_C
St. Louis, MO
2005 St1300
8568
The Orange TPMS will also. I set mine up to alternate between pressure and temperature on the display. Sensors are internal wich has good and bad points, but should give more sensitivity to tire temperature.
Lot's of options. Will want to know how yours turns out in case my Orange dies.
Yorktown Heights, NY
1799
I still have two Orange TPMS units available for sale, but will be very interested to see the results of Steve's unit as I have no loyalty to Orange and no love loss :D
SteveST1300
Vendor
Ledgewood, NJ 07852
03&04 ST1300
5079
I hear you Larry I hope it is a good reliable unit looks like this company primarily does trucks tractor trailers etc. But talking to Deion he told me their MC unit will also do a trailer you just have to program the sensors. So it sounds like what I have been looking for. I might have gone for one of the Orange units but after reading about what happened I decided to look elsewhere. Also the external sensors are easier to service and you can change the batteries in them.
Throttlejockey
Padden is my hero
San Diego
06 ST1300
8080
Do you have to re-balance the wheel when you install those? I would consider a set.
SteveST1300
Vendor
Ledgewood, NJ 07852
03&04 ST1300
5079
I would think it a good idea to rebalance my set has shipped I should get it n a day or so I can then let you know what it actually is like.
SteveST1300
Vendor
Ledgewood, NJ 07852
03&04 ST1300
5079
My TPMS is scheduled for delivery today. Can't wait to get home now. Looks like with tons of snow on the way this is going to be a maintenance and farkeling weekend.
DaveM
Wilton, NH
2021 BMW 1250GS
7806
This is when living in a condo is good....no snow clearing for me!!
sent from my Droid phone.
Throttlejockey
Padden is my hero
San Diego
06 ST1300
8080
No doubt Dave. I enjoy my 300'+ secluded driveway except when it's winter and I have to clear it.
