Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    Site Supporter maximark's Avatar
    1994 ST1100
    Join Date
    Aug 2012
    Park Ridge, NJ
    Posts
    176
    My Gallery
    ST 1100 fork spacer
    I'm about to rebuild my forks. Just received new bushings, oil piece and seals. Bought Progressive suspension springs which came with PVC pipe. If I understand from other threads correctly, I suppose to cut the pipe to the certain length. What's the correct length that I should cut it to?
    Mark
  2. #2
    Site Supporter DaveM's Avatar
    91 SSM-ST1100
    Join Date
    Jan 2009
    Haverhill, MA
    Posts
    1,924
    Tip Overs:
    1
    2013 Miles:
    009200
    My Gallery
    Re: ST 1100 fork spacer
    What do the directions say? If I remember right, I think you use the pvc in place of pipe? I could be wrong, I would have to dig up the directions when I did mine.
    sent from my Droid phone.
    Dave M. 1991 SSM-ST1100 STOC# 7806 IBA# 54116
    Some 2013 Adventures....... 50cc - Jax to SD, Hoover Dam, Route 66, Grand Canyon, Santa Fe, Moonshine, Bennington RTE's, Twisted Throttle open house, WeStoc XVIII, British Columbia, Banff, Jasper, Curtis BBQ, NNEStoc, Blue Ridge Gathering, SS2000, BB1500 and I am sure other adventures will pop up as the year goes on.
  3. #3
    GreenZR's Avatar
    2000 ST1100
    Join Date
    Sep 2011
    Springville, Indiana
    Posts
    270
    2013 Miles:
    004454
    My Gallery
    Follow the directions that came with your springs! They give you a sheet that has the ST1100 listed. We just installed Progressive springs in RCB's, and did fork bushing and seals in both his and mine. On RCB's the sheet said to cut the pvc down to 3.25 inches and put it in in place of the longest metal spacer, and leave out the short one.
    Gary Flynn
    2000 ST1100 1991 ST1100
    1978 KZ650C2 1977 KZ650C1
  4. #4
    (Threadstarter)
    maximark's Avatar
    1994 ST1100
    Join Date
    Aug 2012
    Park Ridge, NJ
    Posts
    176
    My Gallery
    Quote Originally Posted by GreenZR View Post
    I don't think that springs came with any directions. I'll have to look again in the box.
  5. #5
    Site Supporter vinny's Avatar
    1999 ST1100
    Join Date
    Feb 2009
    Dahlonega, GA
    Posts
    1,620
    Tip Overs:
    4
    My Gallery
    The spacers are to set the "proper" preload on the front springs. The recommended length is a general guideline, some folks like to play around with it some. If you make them too long, the ride will be harsh... a little shorter and your suspension will be mooshy and not handle well. The first time I installed the Progressive springs, I followed the instructions that came in the box and the job went very well. You will need a special tool to deal with the right side dampening rod.
    I am not young enough to know everything!
    Where are we going, and why am I in this handbasket?
  6. #6
    (Threadstarter)
    maximark's Avatar
    1994 ST1100
    Join Date
    Aug 2012
    Park Ridge, NJ
    Posts
    176
    My Gallery
    Quote Originally Posted by vinny View Post
    whats the tool called? Or how does it look? Do you know? Shoot! Now I have to look for it. Or find a loaner.
    Can it be subsidized with something else? What you mean "to deal with right side dampering rod"? There was another thread yesterday about using tight downs to compress the spring to loosen the rod. Is it the same thing?
  7. #7
    Gotta make tracks Mark's Avatar
    ST1100
    Join Date
    Jan 2005
    Tempe AZ
    Posts
    16,869
    Tip Overs:
    2013 Miles:
    001646
    My Gallery
    You set up the front end almost the same way you set up the back.
    Measure cut adjust, repeat until satisfied. Read up on front end setups.
    The tool threads onto the rod allows you to get the keeper/washer out.
    If you love your bike, let it go.
    If it comes back, you high sided.....
  8. #8
    1999 ST1100
    Join Date
    Feb 2009
    Dahlonega, GA
    Posts
    1,620
    Tip Overs:
    4
    My Gallery
    The tool screws onto the top of the damper rod and allows you to hold it while compressing the spring and installing the keeper. It can be fabricated fairly easy with some metric hardware. It's been awhile since I made mine... and I think it is a 10mm size. If you PM me with your address, I'll be happy to loan you the home made tool.
  9. #9
    91 SSM-ST1100
    Join Date
    Jan 2009
    Haverhill, MA
    Posts
    1,924
    Tip Overs:
    1
    2013 Miles:
    009200
    My Gallery
    The first time I took my forks apart I attached a piece of twine/string, something to hold the dampening rod from falling back into the tube.
    Since I custom made a piece that attaches to the rod. Yes, it is a 10mm.
  10. #10
    DeanR's Avatar
    1991 ST1100
    Join Date
    Jul 2007
    upstate ny
    Posts
    1,658
    Tip Overs:
    2
    My Gallery
    Pictures of this tool, homemade or otherwise anyone?
    1999 ST1100
    1991 ST1100
    1980 Yamaha XS1100
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
