1) are all green wires grounds?
2) where should that one go?
Of course both wheels need to be turning... there are sensors on both. I am learning more and more as I ask questions and read. Sorry if I post frequently... just anxious to understand.The system cannot initialise itself until it can verify that both wheels are turning at the same speed - and for that, you need to have the bike rolling on the ground at more than about 5-6 mph
Never done this. Is it possible to walk someone through this?Could be worth powering the pump directly (through a fuse) and see does it work ok
Sensor connector? Are you referring to the relay? or the plug that attaches to the motor?check the voltage between the pins on the sensor connector
