What Size PR3 on Rear of NonABS ST1100
Moon, VA
1991 ST1100
8654
Hi,
I am thinking about buying these Pilot Road 3 Michelins, but have seen others use the 160/60-17, the 170/60-17. There is also a 180/55-17 size. How does the diameter of this size compare to the stock 160/70-17? Is there enough room width-wise for the 180/55-17 to fit my old 1991 ST1100? The michelin website does not list width nor diameter of the various tire sizes.
Lexington, KY
1998 ST1100
8643
I'm curious as well. I'd love to try the pr3's but I would really hate to make the bike stand up even straighter than it already does on the side stand with a smaller tire. I think the lack of lean contributed to the tip over I had.
richpeabody
Venice, FL
ST1100
yes
I put the 170/60 on mine....plenty of side clearance.....
The tire lowers the bike about .4"........the side stand is no problem, nor is the center stand....
I would be leery of the 180, as that width might prove dangerous with the rim width.
Have fun!
Bigmak96
R.I.P. - 2021/08/07
Rural Mn
04 GL1800 Past tense
7910
Being a smaller dia. tire you need to watch how you park. It will stand more vertical and be prone to being pushed over. I actually too about an inch out of my side stand to get the lean back. That is the only down side, the PR2 and PR3 will put a smile on your face.
Lexington, KY
1998 ST1100
8643
This is what I have heard and am concerned about. I don't really want to hack up my side stand though. Maybe I need to watch eBay and find one to butcher so I can have the best of both worlds!
Uncle Phil
4 ST1100(s)
002064
698
Folks have run 170/60 for years (I've done it a couple of times) on ST1100s, but there can be the side stand issue and it's a little harder to get up on the centerstand. With the sidestand, a lot depends on how much play you have in it (the wear factor) as to how straight it stands up.
Bigmak96
R.I.P. - 2021/08/07
Rural Mn
7910
Don sent a PM asking about the shortening and it made me realize I was thinking about the shorter car tire. I had the same issue with a PR,,just not as bad as with the CT. The fix is the same but an inch may be too much. I would put the side stand down and hold the bike vertical. look at the space under the foot and let it down. Visualize what a half inch off would do and go from there. Hopefully you have a welder who will do it for a reasonable price in case adjustments need to be done.
