I like to do my own work and have have referred to this site many times to draw upon the collective knowledge. But now I have a problem and need a little help. I've got a 2004 ST1300 with 70,000 miles that up until recently has been starting and running normally. After doing the work listed below she won't start, the engine turns over but it will not start. Other than a dead battery a few years back I've never had any starting issues. I performed the work listed below over the course of 2-3 weeks during which I never tried to start it. I suspect I've failed to reconnect something or have accidentally pulled a connector loose but just can't find it! Any assistance you can offer to help me resolve this problem will really be appreciated.
Thanks,
Alan
Recent Work Done
Installed farkles, both on bike without any problems since 2005
What I?ve checked
Thanks,
Alan
Recent Work Done
- Replaced air filter
- Installed new tires front and rear
- Replaced fluid and bled brakes front and rear
- Replaced fluid and bled clutch
- Disabled windscreen motor by removing cables from gearbox
- Replaced thermostat and coolant
- Installed new Yuasa (YTZ14S) battery
- Installed 4 new spark plugs
- Audiovox cruise control
- Symtec grip heaters
What I?ve checked
- Loose or disconnected electrical connectors
- Put in 1.5 gallons of fresh gas, gauge show 1/2 full
- Checked voltage drop at battery during start, get 11.2 volts
- Checked for spark at each spark plug, have spark
- Checked for FI Codes and found none
- Checked IAT Sensor according to the shop manual
- Checked Bank Angle Sensor operation, relay clicks when tilted to left or right
- Checked CKP Sensor connection for clean and tight connection, looks brand new
- Disconnected cruise control power and tried to start, cranks but does not start
