kiltman
- Joined
- Apr 27, 2013
- Messages
- 3,282
- Age
- 68
- Location
- Stratford, Ontario Canada
- Bike
- 2002,ST1100ABS
- STOC #
- 8826
I modified the black plastic piece above the headlight which I understand to be called a "Garnish". Mine is missing two plastic tabs that lock it onto the cowl, resulting in some movement on the windshield. I have a rather tall windshield and I suspect along with age (my bike is a 1990 23 years old) is what made them fatigue. Replacing it is an option but expensive. I decided to install windshield screw grommets near where the tabs are supposed to be located. ( I would have installed them lower but it wouldn't work because of the headlight housing.)
I measured and marked the desired location, drilled the appropriate size holes and installed the grommets and refitted the garnish.
i'm pleased with the result, the windshield is firmer, less whistling at speed because of the lower part of the garnish secured to the cowl.
The photos show the gap, measuring prior to drilling, the finished look as well as what the grommet looks like.
i bought a package of 10 grommets for under $10. The spares I can use for replacements when needed. ( John, in posts to follow has correctly named them wellnut)
