01 ST1100 ABS No brakes!
STurgisSTeele
When did I become the "Old Man"!?
STurgis, MI
01 ST1100A (RIP)
2667
Breaks felt soft, both lever and pedal. It got worse and worse by time I made it home (2.4 miles). Sitting in the drive I could pull the lever all the way in. Backed the bike into the garage and that's it. I hadn't the time to do any checking. But plan on checking the fluid level in both reservoirs and if the level is good, check for any blown fuses.
Any culprits or usual suspects here? 226k on the clock.
Sent from my iPod touch using Tapatalk Pro. Check it out!
Dahlonega, GA
2018 NC750X
7666
If the lever has gotten soft, then there is air in the system, might be low on fluid. (I'll just keep guessing until I get it right):)
STurgisSTeele
STurgisSTeele
STurgis, MI
01 ST1100A (RIP)
2667
Sorry, I just haven't checked anything yet. I may have a few minutes in the morning. I haven't had any problems till now. I was going to change the fluid this winter season since I don't know when it was last changed. Mark might know, if he sees this thread, he might join in.
Bigmak96
R.I.P. - 2021/08/07
Rural Mn
04 GL1800 Past tense
7910
Fluid should not be too old, couldn't hurt to flush but it was all done prior to last seasons start.
Weird, first UP and now you, it is an epidemic.
STurgisSTeele
STurgisSTeele
STurgis, MI
01 ST1100A (RIP)
2667
Thanks Mark for the info. I'll post later when I check it out.
Bigmak96
R.I.P. - 2021/08/07
Rural Mn
7910
John, I would look for wet areas and see if a line has loosened up. Or refill and pump to see if you can see it leaking. To loose the peddle and lever,the fluid has to be going somewhere. Good luck.
STurgisSTeele
STurgisSTeele
STurgis, MI
01 ST1100A (RIP)
2667
My thoughts exactly. Hope it's something simple.
Alief, TX, USA
7461
Both master cylinders at the same time? Very unlikely. Either master cylinder by itself wouldn't result in the symptoms described. Neither would any of the fuses.
STurgisSTeele
STurgisSTeele
STurgis, MI
01 ST1100A (RIP)
2667
I wonder if I imagined the pedal being a problem. The pedal seems okay, but I can pull the lever all the way back. Appears to be plenty of fluid up top.
Bigmak96
R.I.P. - 2021/08/07
Rural Mn
7910
Start with a thorough bleed John. That may be all it is.
Given that it sounds like its just a problem at the lever, and not the pedal, then go back to John's comment about the master cylinder. If fluid is leaking past (whatever creates the seal) so it can't generate any pressure, I think that would be consistent with the symptoms you're describing. Haven't had to rebuild my non-ABS master cylinder so I can't be more specific about the details, but that sounds like a good place to start looking. Maybe someone else who has rebuilt the MC can chime in with more specifics.
I've had master cylinders go out on cars before, and its exactly as you describe, the pedal goes to the floor without applying the brakes. Fortunately in those cases I was able to pump it a few times to get enough pressure to stop the car.
STurgisSTeele
STurgisSTeele
STurgis, MI
01 ST1100A (RIP)
2667
Thanks fellas. Sorry for the delay in response. First chance I've had since being in Indy foe a wedding. Will be home later today and order the kit.
STurgisSTeele
STurgisSTeele
STurgis, MI
01 ST1100A (RIP)
2667
Good idea. Too bad I didn't think of this when ordering. Maybe I'll be able to combine orders if the first hasn't been already done. Thanks for the advice.
STurgisSTeele
STurgisSTeele
STurgis, MI
01 ST1100A (RIP)
2667
Installed the master cylinder rebuild kit, pulled new fluid through both sides, and bled both sides, though there wasn't any air bubbles. But when the diaphragm, that plastic piece, and the cap were reinstalled, there still wasn't any pressure at the handle when applying pressure. The handle pulls back as easily as when the cap and other pieces were removed. I don't see any leaks. And I believe I have all the air out. So I'm back to how it was when I lost the front brakes.
Any thoughts on what it might be or what I should look at or test?
TIA
Sent with Tapatalk Pro.
