Wow !! The cost is almost unbelievable - worth a shot, maybe. I wonder if they are pressure tested ? I guess the purchaser can do that after they are installed ............ but definitely good for the clutch hose.
BTW, hose assemblies made by Brake Material & Parts are pressure tested to 3,000 psi and therefore are DOT qualified.
The other problem may be the orientation of the fittings on the Chinese hoses. The Chinese hoses may not fit without having a twist when installed. With Brake Materials & Parts, you send them you old hoses and they copy them, including the orientation of the fittings. They also use any T-fittings that are used in the OEM hoses. I was surprised about that.
