Suzuki Bandit 600 questions
v8-7
Bradenton, Fl
Hi Guys,
I'm going to the Isle of Man this spring and have reserved a GSF 600 to get around while there.
The trip will start out in London , ferry over to the IOM for a week to watch the TT race , then about 5 days to ride around Ireland.
I have some questions on the bike .
Will my magnetic tank bag work ?
How do the ergos compare to the ST1300 ? will it be more upright or more sportbike like ?
I've purchased a 12 volt outlet to temporarily install, Will it be easy to access the battery terminal for that ? Are the battery bolts about the same size as the St1300 ?
Thanks , Stan
010688
Can't answer a single question but I'm green with envy Stan! Have a great time on this trip.
SteveST1300
Vendor
Ledgewood, NJ 07852
03&04 ST1300
5079
I wish I could help you Stan but I too would love to make that trip. Just to get a chance to ride the IOM course would be worth it. Take some pictures or video of it if you can maybe you can show us a movie at FLSTOC later in the year. ENJOY!
Nebraska
The Bandit is a great bike. That's what I traded in when I got the ST1100 and mainly just because it wasn't powerful enough to ride with 2 adults and still keep up with the rest of the group. The Bandit is a very comfortable ride and has a much more standard upright seating position than most sportbikes. As someone else stated it does indeed have a metal tank so shouldn't be a problem with the tank bag and the battery is relatively easy to access. If my wife would have let me keep it I most certainly would still have it. I may pick one up again someday to have as lighter errand running bike.
Weatherford, TX
'16 Versys 650LT
1134
Hi Guys,
Are you sure it's not a GSF 650? I believe the 600 was discontinued in 2005.
This website will give you numbers for the difference: http://cycle-ergo.com/
.....ST1300 - forward lean = 8 deg.
Bandit 650 - forward lean = 12 deg.
Bandit 600 - forward lean = 17 deg.
There are other measurements on the site that might be of interest to you.
I've got a GSF 1250 and it has the same ergos as the 650. There is a definite difference between the ST's ergos & the Bandit but it's not hugely noticeable. It's like most Standards I've ridden. The ergos are nowhere near that of a sport bike. For instance, the CBR600 has a forward lean of 29 degrees.
I'm pretty sure the 650 has a metal tank so your tank bag should work.
If you want some particulars on either the 600 or 650, go to Maximum-Suzuki.
veefore
See you at my intervention!
N.W. CT
15' BMW R1200RT
3244
You're taking a trip that's on my bucket list.................I'm jealous. Have a blast! Hoist a pint for me at Bushy's :capwin:
P.S Quite frankly I'd do that trip on a Sportster with one bad plug..........
Olympia, WA
2003 ST1300
I owned a Bandit 1200 for 3 years. The Bandit had a longer reach to the handlebars, so more pressure on the wrists and shoulders. It is still considered standard, so its not a CBR racing position. Its fine for a 100 miles, but I traded it in for the ST as the comfort factor is so much greater on the ST. Also, the 600 has an easy reach to the ground, a turbine smooth engine and weighs 200 lbs less than the ST. Good luck.
v8-7
v8-7
Bradenton, Fl
Thanks Mick, the bike was a 600 and after checking the mentioned ergo site, it was significantly more "sport' than the 650 which is also around an inch lower .
So I was able to change that to the 650 .
