I know that it's a valid code, just not sure about the way I obtained it. While on my A-Z ride this afternoon, the FI light came on about 40-50 mi from my destination. When I got there, I was hesitant to shut off the bike for fear it might not restart, and I was 100+ mi from home. I parked the bike, left it running & put down the side stand. Noticed after I did that the FI light started flashing, giving a failure code 26. Didn't know until I got home what that indicated (right knock sensor), but since I didn't obtain the code following the SM procedure of shorting the PGM-FI service connector terminals, I'm not sure if it's valid or not. I repeated the "check" 2 or 3 times during my afternoon ride and got the same sequence of "long" & "short" flashes each time. What puzzles me is that I had a brain fart a few minutes after first observation of "26" and absentmindedly put the side stand down while it was in gear, killing the engine - it restarted no problem, the FI light did not come on after starting the bike. It came on again after riding a few miles, stayed on until I stopped to refuel, 20 miles from home. After refueling, the FI light hasn't lit up again, other than when the key is first turned on & fuel pump is pressurizing the fuel rail. I assume I need to follow the SM troubleshooting procedure to confirm the problem? Any ideas or other suggestions?
Don
Don
