Need some suggestions.
I pulled the airbag off to add in a Rosta cruise.
Reassembled the airbox after double checking all the linkage moves freely.
Start bike, idle sounds high and climbing. Settles in around 4500
After a few minutes it starts dropping as the engine warms. Once I'm at 3 bars the idle speed is down to 2500.
So what the heckler is going on.
What I do know:
Wax cylinder is operating properly.
Antifreeze is good and topped off.
Set idle screw is backed all the way out. Screw it in a bit and engine rpm climbs.
I reattached 3 houses to gas tank.
2 vacuum hoses attached under airbox.
Throttle moves cleanly, butterflies are closing.
Killed and restarted bike, same thing happens.
Let bike cool down completely and the same routine occurs.
Blipping throttle just does what it should.
Did I forget a wire somewhere?
Oh... I checked 5way while in there and clean.
Any help appreciated, especially if it saves me from totally removing the tank.
Thanks,
T
What I do know:
Thanks,
T
