Average miles per gallon
Dayton, Nevada
'07 ST1300
7534
My reading is stuck at 38.7, and hasn't moved during a 200 mile trip. Does anyone have an idea where to start checking? The fuel gauge is still reading accurately, just the average miles per gallon doesn't move. Any suggestions?
Central Florida - Orlando area
ST1300/GSX1300R
That gauge has 3 settings:
1. Average MPG
2. Current MPG - The setting most people use.
3. Off - Shows all "-" or "_" 's
Maybe I should have had "Current" first. I didn't find this in the manual, I found it the hard way. I changed it and wondered what had gone wrong with the display.
It might be this simple.
Blrfl
Natural Rider Enhancement
Northern Virginia
Fast Blue One
4837
The average MPG indicator gives you the average since the last reset. If you don't reset it, it's going to give you a very-long-term average that will move less over the short term.
--Mark
970mike
Mike Brown
Lompoc, California
07 & 12 ST1300A
SPOT
LINK
8057
Ed, I would just reset it by holding the button down and then I am sure you will see it change.
EASt
Streuselkuchen
Minnesota
S1000XR
What everyone above has already said, or maybe you're just the single-most steady throttle hand on the planet!
T_C
St. Louis, MO
2005 St1300
8568
To reset the average you need to disconnect the battery. You will also need to reset you clock.
Well that is certainly one way to do it... or you could just hold down the fuel (is it FCD?) button for 3 seconds.
