- Joined
- Feb 18, 2007
- Messages
- 47
- Location
- Ottawa Ontario, Canada
- Bike
- 2013 Yamaha FJR1300
- STOC #
- 3393
I am seeking the wisdom of this group to help me solve an issue with a 1984 Vt500 Honda Shadow.. Mileage 45 k ( Kilometers). Sometimes known as the Ascot it?s a Twin cylinder 500 CC.. Two CV carburetors, dual coils, Dual spark (CDI) ignition (two sparkplugs per cylinder) 6 speed, shaft drive
Symptoms: Surging or loss of power in the upper RPM range (4.5 to 5K RPM equating to 50 -55 MPH ish in 6th gear. The issue is consistent in 6th gear and intermittent in 5th gear at similar RPM?s. In 6th gear when applying additional past 4.5 to 5K the throttle has no effect and the bike will actually drop in road speed ( RPM drops by about 2 K before throttle is again responsive. if you shift to 5th then throttle is immediately responsive .) There is no perceived similar loss of power in the lower gears at any revs. Issue started at beginning of the season last year and seems to have gotten progressively worse.
Things tried so far
Ignition: Swapped both coils and CDI units with ebay sourced units ( Used) No change using any combination of original and the ebay units. New Spark plugs. No perceived arcing of dry or wet plug wires to any ground source (Dark Garage) Wires show good with ohm meter.New Battery this season ( Bike always starts and idles fine)
Fuel:
Used ancillary fuel tank to bypass the vacuum actuated petcock in original fuel tank, I used an ultrasonic bath/ cleaner on the Carburetors (Twice) No perceived holes in CV rubber slides. Float heights appear to be within spec. ( I don?t have the special gauge required.) No evidence of anything missing or damaged and no air/vacuum leaks found..
Ideas ??
Things tried so far
Fuel:
Ideas ??
