st1100 abs stopped working
northern ireland
cb1300sa7 cb1300sf
hi guys
I look after my mates 1998 Honda st1100 abs/tcs model...
ever since I changed the rear brake pads and new brake fluids front and rear the abs has stopped working...as well as the traction control...I did the fault code check and it was showing error code 6 if I can remember showing the rear abs sensor....
well it has seized in its housing.....
we don't believe we can hear the abs pumps whirring when the ignition has been switched on..
the other day when he was riding the bike it went into limp mode and the tcs light came on....
another time recently the front brake lever when he went to brake was solid.....
yesterday we did the fault code check and its not giving me the code...the abs lights just flash continuously with no interuptions unless I press the abs switch
any help guys...would changing the rear abs sensor sort this out?
thanks
sean
