Rear Shock Questions
Pearland, Tx.
97 ST1100 04 ST1300
8492
OK, I've got a few questions which answers will spark some more I'm sure (hope anyway). I've got a 97 with 90+K miles and am wondering what difference a rear shock change would make. I've changed the front fork seals and oil (and head bearings) and that's nice and all, but I'm wondering about the rear. I'm not a speed demon so I'm not pushing it to the edge or anything, but ...
I'm changing the belt and water pump and checking out the various parts and pieces soon so I was thinking of what other things might could get changed. Would it make a real difference? FWIW, thinking of the Progressive 465.
Mark
Gotta make tracks
Moderator
Apache Junction AZ
KTM 525exc
3768
Simply put, IMHO:
The rear shock and spring replacement will make the bike feel like a new and different/better! bike.
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
If this is the original shock you're replacing you will notice a difference. Some say the OEMs are good for around 40-50K. I just put on my 4th Honda OEM shock today, along with the 14th or 15th rear Exedra. Suits me fine with Progressive springs up front. Our Ricky Racers will recommend their favorite aftermarket shocks.
FWIW
via iPhone 4S
Springville, Indiana
2000 ST1100
001387
8497
My OEM rear shock died last year. I went with the Progressive 465 and I like it. Just mount it upside down so it clears the inner fender. I ride about 70% solo, & 30% with my wife with me. I think I still need to increase the preload on it, but very happy with it.
Sunday Rider
Aurora, Ontario
1997 ST1100
6136
I like the Works Pro Racer as well. You can send it back to Works to have it rebuilt whenever it starts to leak. I have one on its way back to me now. It cost $160 to rebuild, including a new shaft (this added $45). So think very reasonable. A new rear shock whether OEM or aftermarket will make the bike feel great. As long as you take time to set it up correctly.
Paris, TN
'99 ST1100
8606
I replaced the OEM shock with a Progressive 465. I used to have to increase the preload on the OEM shock every time I rode 2-up. It is harder to adjust the preload on the 465, but I found that the factory settings are fine for solo or 2-up.
+ 1 to both...
But you then should consider to "match" the front suspension to it (no use to have a "stiff" rear, but a sagging front then...)
At least a stiffer fork oil (like 7W or 10W), or maybe even after-market springs as well...
I'm always amazed when switching from the '00 ST, with Wilbers shock and Hyperpro fork springs, on the '94 with its genuine OEM suspension...
The OEM isn't "bad" per se, but compared it rides like a sofa, bobbing and rolling like an 80ies Oldsmobile estate... :)
Yes, nice for cruising, providing a very comfy ride, but once you want to hammer that rig through a fast or narrow turn, you go like "...uoops...uoooops...UOOOPS...!!!" :lol:
Especially "nice" when the rear starts to wiggle and dance while passing a car/truck at about 100mph... ;-)
