So, I'm a relatively new ST 1300 owner. It's a 2003 non-ABS model, which was what my budget would allow. Would love to trade up to an ABS model someday...
I've had it six months, bought it with 45k miles, and it's been running flawlessly. I haven't had a chance to take it in for a dealer service yet (just a diagnostics check?), but I've done some basic maintenance, like changing/topping up fluids, new tires, checking brakes, etc. However, just in the last couple of weeks, it's had trouble holding an idle. It will just stall out. It was only happening occasionally on some starts and my temporary solution was to hold the throttle open for a bit until she warmed up. Then it happened a couple of times as I pulled up to a light. As I decelerated to a stop, the engine would die, but always started up no problem. Today, though, it happened twice while moving. Once, while on the freeway as I coasted to an off ramp, the engine died, but I hit the starter button and it started right back up. It happened again a few hours later on a surface street as I rounded a corner. The engine died on my down shift and this time it wouldn't restart at all. I stopped by the side of the road and tried to restart it unsuccessfully a couple of times. I waited just two minutes, tried again, and it started right back up. Didn't happen again on the rest of my ride home, although I was paranoid every time I decelerated.
A couple of months prior to this, when I had the lower fairings off, I found this little rubber thingy in my driveway. It's only about an inch long. It looks like it belongs to the ST, but I'm not sure. Does anyone know if it does and if it may be related to my little stalling problem?
Thanks for any advice or suggestions!
