Too much for one thread I'm sure, but ...
First off, and I've touched on this once before, I have a starting issue. Occassionally when I hit the starter button I get the same response as when pushed with the kill switch engaged (only the kill switch is not engaged) - lights dim and it doesn't turn over. Usually, a push or two later it will turn over and crank. Occasionally it cranks mid push (if held for a few seconds). Sometimes however, I feel I am one push away from being stick somewhere (and would love to avoid this). I'm thinking a starter relay or maybe a bad kill switch, but would LOVE to know where to look. And since I will be doing the following and have much of the plastic off ....
Next, I am FINALLY going to undertake the timing belt / water pump change. It will also be the first time I check the valves and my guess they will need some adjusting (I haven't checked them and who knows about the PO - bike has 93K and a knock from time to time at @2500 rpm - and they sound pretty tight). I have the ST1100 Valve Clearance Worksheet and have read a bit about the valve adjusting and TB/WP replacement, but I'm open to any tips or tricks to make either easier. Also, what other things should be checked when I have the cover off for the belt and pump?
I realize there's a load of questions here, but .... Afterall, I'm not in my prime riding season here (IT'S HOT) LOL!
Oh, and I plan to add a cruise control to it while I have it apart too (One I bought a while ago - clone of the Audiovox I think)
