The inner spring and small seal was likely the issue on old cap if the outer rubber seal had no cracks in it.
On re-inspection, as I was writing from memory... It's the red 4p connector that's burnt out in the upper right corner. Can I order these plugs from Honda? I tried one of the links some suggested, Beaver Power, but I can't make sense of what connectors I really need...
I used a stat from an early 80's Honda civic, cost ?5,exact same stat, the oem stat was 50.I did not replace the thermostat and some research shows that if it does fail then it will stick open anyway. I don't mind replacing it if that turns out to be the issue but I was not able to find a suitable auto part number as the Honda OEM is supposed to be quite expensive.
What about the O-ring for the t/stat case? Does the Civic one fit too?I used a stat from an early 80's Honda civic, cost ?5,exact same stat, the oem stat was 50.
I can't remember Martin,it was a few years ago,I posted about it at the time. I'll have to look back through my old posts,I don't remember replacing the 0 ring though I may have bought one for it in a local marine supply shop.What about the O-ring for the t/stat case? Does the Civic one fit too?
