Ok, need some advice. I picked up a 2002 ST1100 that had been sitting for a while. She wouldn't idle and needed the choke on all the time to run. Thought it was old gas/dirty carbs, so I ran several tanks of sea foam through her with only marginal improvement. Checked the plugs and found that one was very fouled and traced the problem to the associated ignition wire. I replaced the wire and then, no spark to any of the plugs.... Went through the troubleshooting diagram in the service manual and everything was ok, so I replaced the ICM with a used module. Still no spark, but all the trouble shooting tests were still ok. Took everything apart, put in the original ICM, coils, and wires, and made sure all my connections were as tight as could be. Put her back together and now have spark to all plugs. But still no start.
With all this testing/replacing I've had the ignition coils pulled out several times and run the battery down trying to crank her over (so now I'm using jumper cables to make sure I've got good battery voltage).
And then it came to me. Even with all the cranking I'm not smelling fuel. She never has that flooded smell.
So, starting to think I've done something that has impacted the fuel system. The fuel pump still whines when I turn her on and she'll fill the fuel filter, so I'm thinking it's not the pump.
What next? There is no handy trouble shooting guide (measure this at this location, kind of thing) in the service manual.
Is there something obvious that could have become disconnected with all the times I've pulled the airbox and ignition coils?
Is there a way to test the vacuum system using basic tools in my parking lot?
Any help would be greatly appreciated.
