weird event riding to work this morning.
West Michigan
'98 ST1100
8470
I'd wait to see if it happens again. If it does, it will not be easy to trouble shoot if the problem remains intermittent .
Please let us know if it happens again. I have a few ideas you may be able to use. If you have time now, you could check a few things with an Ohmmeter after removing some plastic to gain access to some electrical connectors. Like the Run/Stop switch, kickstand switch, and ignition module electrical connector, etc. I can give you more detailed info. , if you desire.
superdiver
Ketchikan, Alaska
1984 Shadow 700
What it turned out to be was a bad key connection. If you wiggled the key it would just shut off. I ended up removing the key cylinder and cleaning it out good.... problem fixed...
STooRay
Norway
Glad you solved it:hat2:
I must say these threads are incredibly inspiring and educational.
Thanks to y'all !
STooRay
Fatjock
STOC #8872
Tampa Bay Area
'18 Glowing Tour DCT
8872
Well done. As Jim Van said, intermittent faults can be a bear.
Very glad you got to the bottom of it.
