+1. You should have plenty grip having to work the throttle and brake levers, or if you're a lefty the clutch. The grip also works for pickle jars. When you get to it, be sure to press the wire clip in toward the bulb and the slide it up.There are two latches on the side of the connector that must be squeezed FIRMLY before it will pull off the bulb. I found it tough to squezze them and then pull, but it did come off. Good luck.
And use the Force young padawan.Remember, you have to BELIEVE it will come off.
I ruined my left headlight connector by my ignorance of not squeezing the tabs and pulling too hard. I replaced it with a heavy duty H4 connector from O'Riley's and all is well.I have a small hand and can reach the connector without removing any Tupperware, but I cannot seem to budge it. This should pull straight off - correct? Any suggestions?
Burlster
