I agree with what others have said... calculate your mileage manually through multiple tanks. My suggestion would be 3 to 4 tanks because mileage will definitely vary. Your 6L/100km figure, which converts to 39 mpg, is a bit low but could actually be the result of a slight error in gathering the basic info used to compute the fuel usage. If you consistently see this 6L/100km figure through 3 or 4 tanks, then you can be assured that this is accurate.
Here is how I keep track of my fuel consumption. First off, pay no attention to that blasted fuel consumption figure on the dash screen! The only way to get accurate fuel consumption is to manually compute it yourself.:
1. Fill up your tank to an easily identifiable point in the filler neck EACH time. It's important to be consistent in this. I (consistently) put my bike on the center stand and fill to where the gas level is just touching that little horizontal bar that is on one side of the filler neck. Be sure and get a receipt that shows gas volume put in the tank.
2. Record the bike's mileage on the gas receipt. I do this by scratching the mileage on the receipt with my key.
3. Ride through at least 2/3 of a tank or more (say 200 miles <322 km> minimum) to increase accuracy of the resulting computation.
4. Repeat #1, #2 & #3 through 3 or 4 tanks beyond that initial fill-up where you recorded your first mileage.
5. Enter this information into a spreadsheet. Set the spreadsheet up to compute your fuel consumption from the kilometers and liters you've entered. If you're unfamiliar with spreadsheet computations, we'll help you with the formulas needed.
....Here's a screenshot of part of the spreadsheet I used for the month of March. I've done this for every motorcycle & car I've owned in the last 20 years. I just input the odometer mileage and fuel used at each fill-up and it automatically computes the mpg. In this case I added a column of L/100km figures (in red) that were computed from the mpg numbers. Notice how the consumption #'s can fluctuate, in this case as much as 4 mpg. The variation could be caused by the weather (wind), riding style, or terrain. :
Once you've made reasonably accurate calculations over several tanks, you'll have a feel for what your real fuel consumption is and you'll have a number that you're sure of. At that point, the folks on this forum can help you logically proceed to a solution which might be as simple as running Seafoam though your tank.
