lock serial number identification "1AB"
Oman
ST1100AY
Hi, I need to get a new key, my existing one is so worn that it is very fiddly to get the lock to work (any lock on the bike).
I have tried a blank cut duplicate but same problem, probably because the master key is so worn.
I took the lock off the fuel cap and found 3 characters stamped into the side of the barrel, the sort of stamping you get with a hand held punch (they aren't uniform)
the characters are <number> <letter> <letter> , that's all, e.g 1AB (thats not the actual characters !) This is somewhat at odds with the information I have read.
Do you think this is the reference I need to get a replacement from Honda ?
I did try my local dealer (Dubai) but they say that Honda Middle East won't supply factory cut keys only blanks. This means I need to try a US or European dealer and wanted to make sure I had the correct info.
I was going to post a picture but then thought better of it !
Thx Steve
West Michigan
'98 ST1100
8470
Yes, That code describes the key cut. A good locksmith can create a new key from that code. If you look at some other keys you will notice the 3 character code stamped or written on the key. It's a good idea to write those codes down if they are simply written on the key in ink.
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
Any good Honda dealer should be able to cut you a key with that three digit code. BTDT Cost me ~$7 a key last time. My good local dealer, Hawkeye Motorworks, had key blanks in stock and the machine to cut them.
Edit: ST1100 key code info in the Archive Of Wisdom (AOW):
http://www.st-riders.net/index.php?topic=1861.0
via iPhone 4S
aSTerix
Oman
ST1100AY
I was wondering if there is anyone in US who could perhaps pick me up a new key using the key code (not the example code I used) I will PM.
I have a Florida mailing address which then ships out to me in Dubai. I can pay using Paypal plus some extra cash for petrol and time. I will PM across my Vehicle Registration card to prove ownership .
Many thanks in advance, Steve
