I purchased my '06 ST1300 back in July of 2010 with roughly 8,800 miles. Though it has never shifted as smoothly as I would have liked it to, it's gotten progressively worse. By the end of this past riding season, the biking was becoming unenjoyable to ride. I absolutely love the bike and don't want to sell it, but it was to the point where something had to be done. It has roughly 45,000 miles on it now. I accomplished a clutch "fluid swap" last year to eliminate air bubbles in the line. It made no difference in the behavior. I've mostly run Mobil 1 or Rotella, but occasionally have had to run Honda's 10-40W conventional oil because I was unable to find Mobil 1 or Rotella in the local stores when needed. One thought was that the shift linkage under the bike had become fouled with dirt, but that wasn't the case. It was quite clean and none of the dust boots on the linkages were compromised. With the bike on the center stand and the engine *not* running, shifting felt extremely smooth, so it didn't appear to be an issue with the shift drum/shift fork part of the transmission.
I wanted to get it in before my extended warranty runs out (June), so I dropped it off this last week. Two of the technicians rode it and they both concurred that it has the issue I described. They tore into it yesterday and gave me a call this morning. They were suspecting a "dragging clutch" issue. They said that they were a bit amazed at how good everything looks. The metal clutch plates looked almost like new with no warpage. The friction plates looked really good as well. I've never been one to drag the clutch, so that didn't surprise me. The pressure springs all measured within tolerance and were equal in length, though they were just barely in tolerance. They spoke with Honda, and their first recommendation was to completely bleed the clutch, which they did. The local tech said that they found absolutely no bubbles in the system, so that made me feel good that I did a proper job on that last year! The clutch assembly moved as expected when the clutch lever was pulled.
What we've decided to do is to eliminate as many possibilities as possible (within reason) by replacing the friction plates, pressure springs, and then running the exact oil Honda is recommending so that they can't come back and say that we're not following their guidelines. I know that several other forum members have experienced the "notchy" shifting as well, so I'm hoping that the steps taken with my bike and the outcome can help others. The parts are going to be ordered on Monday, so it will most likely be at least a week before I'll post again.
Stay tuned!
Stay tuned!
