No, then I would have no reason to add useless bits of fluff to my replies. .Maybe we should average everyone's reported mpg to get the definitive, final, one-and-only-answer to the original question? How many mpg does an ST1300 get?
That is interesting !! How do you define lower & higher elevations ??snip ........
Both bikes showed 5-10 mpg lower at lower elevations, and 2-5 mpg higher at high elevations.
That 98 musta' been a distant twin to my 92........+1 on the higher elev./higher mileage, lower elev./lower mileage.My 98 st11 averaged 50.3 mpg over 85 tanks, 40.4 low, 56.6 high. It had a +2" windshield, k&n air filter, otherwise stock.
My 04 st13 averages 50.3 mpg over 249 tanks, 38.2 low, 61.3 high. It is totally stock other than added fairing and mirror air deflectors.
There's no elevation that triggers an abrupt change in mileage--it is connected to the fact that oxygen mass per unit volume decreases with elevation, so fuel stoichiometry changes with elevation. If you live at 2000 ft elevation, you'll see higher mileage at higher altitudes from there, and lower mileage at lower altitudes.That is interesting !! How do you define lower & higher elevations ??
If you ride at the elevations here in Colorado most of the time and them go to 1000 feet or less it is like having a turbo on the bike. Like John mentions more mpg for less HP. Somewhere in the neighborhood of 5% loss of HP per each 1000 foot rise in elevation.Someone needs to put a turbocharger on their bike. That would be interesting to see how that would work in higher elevations.
This is related to what I said earlier. Change one of the design parameters and others are affected. Here we are increaseing oxygen in the air per unit volume as we go to lower elevations, increasing the power output, and decreasing the fuel economy. Adding the supercharger (or turbocharger - both do the same but get the power for the compressor differently) simply crams more air/fuel into the cylinder and ups the power. Burn more fuel, get more power, you will lose a few mpg.If you ride at the elevations here in Colorado most of the time and them go to 1000 feet or less it is like having a turbo on the bike. Like John mentions more mpg for less HP. Somewhere in the neighborhood of 5% loss of HP per each 1000 foot rise in elevation.
I read that a turbocharger is ideal for an airplane engine. It is desirable because it "maintains" power at higher elevations ( compared to at ground level ) , rather than increasing power at higher elevations.An interesting manifestation of this altitude phenomenon is that small planes (normally aspirated) are more efficient the higher they fly but their engines also may put out only 50% of their sea level power at altitude. Eventually, they hit their 'ceiling' and can fly no higher. Same exact behavior as what we are talking about but presumably, planes routinely fly higher than most of us ride.
Extra power doesn't necessarily come at the expense of higher fuel consumption, it depends on the compression ratio of the engine, higher compression is more efficient. Supercharging is another way of increasing cylinder pressure, so you end up with the efficiency of a higher compression engine, while also overcoming the effects of lower air density. The tradeoff is being able to avoid detonation as the cylinder pressure increases, but if that can be accomplished you can get more power with the same amount of fuel or less.This is related to what I said earlier. Change one of the design parameters and others are affected. Here we are increaseing oxygen in the air per unit volume as we go to lower elevations, increasing the power output, and decreasing the fuel economy. Adding the supercharger (or turbocharger - both do the same but get the power for the compressor differently) simply crams more air/fuel into the cylinder and ups the power. Burn more fuel, get more power, you will lose a few mpg.
That's turbonormalizing. I know it sounds like I made that up, but it is the legitimate description.I read that a turbocharger is ideal for an airplane engine. It is desirable because it "maintains" power at higher elevations ( compared to at ground level ) , rather than increasing power at higher elevations.
