So, I took the bike out on this gorgeous day to test the speedohealer. Some dummy had programmed the beaste with a -30% correction factor instead of the calculated -3% (I cannot tell a lie, tis moi). The device worked as it should, showing a speed of around 45 mph when my gps said I was doing 65. Got to my destination, reprogrammed it to what I thought it should be, and headed home. The SH is behaving like the directions say - it counts down, I can program it, it reveals the programming, and changes between A & B channels. It also indicates the converson symbol and toggles that feature on and off as designed.
Now, last fall I checked the odometer against the Interstate mile markers and found it to be reading about 10.3 miles for 10 mile marker posts. This calculates out to a -2.9 correction factor but I was now using a -3%. Well, today, on my return trip the odo read 9.1 miles in 10 mile posts (trip meter then, and now, same tires last fall, same tire pressure and it was 61 deg today and was probably in the 50's to 60's back then). Only difference that I can think of is that last fall's check happened at the end of a long ride and the tires themselves might have been warmer than today (only a 10 mile warmup before the measured distance). So I calculated the new correction and added -1% for a -4% total and took her out for a new spin.
This time, I get 10.1+ indicated (estimated at 10.14) over 10 mile markers. Now every one of the test runs have been on different Interstates - though the two this morning were out and back on the same I-480.
Any ideas? My goal here is to get the odometer to read exactly the Interstate mile marker distance and let the speedometer fall where it may. Last fall the speedo seemed to be reading about 7% high compared to my GPS. Btw, the speedo this morning was roughly 20mph low, then 2 mph low, and this afternoon about 2 mph low - so the speedo healer is doing something.
Next step is probably to turn the speedo healer off, and go out to the same section of interstate that I did this afternoon, run it again, calculate the total correction and check that on the way back home over the same section of interstate. Might have to wait a week or so, because I have a heavy work load this week.
A quick aside. Since the speedohealer allows a +9999.9 correction factor, this would make your bike the quickest motorcycle around with an estimated top speed of 14,241 mph. Not quite warp factor 2, but a step in the right direction.
