That's interesting. Here's a photo of a spare wire harness (I believe to be from a 2005 ST) with the tail/brake lamp conductors configured a bit differently.
Here you can see that each of the tail/brake lamp connectors (yes, one of the connectors has been altered) only have three conductors. Each of the brake lamp conductors (Green/Yellow) terminate in a connection with two additional Green/Yellow conductors, hidden beneath the Blue taped-up junction, which is buried within the wire harness sheathing. The two additional Green/Yellow conductors are the brake lamp switch conductors; one from the front brake lever switch, and the other from the rear brake pedal switch.
While these two wire harnesses achieve the same electrical results, the methodology is slightly different.
Back to your original questionNo, the Black/Brown wire is for the tail lamps.
If you want to the install the brake light flasher device, such that either the brake lever, or the brake pedal will cause all the brake lamps to flash, then you will need to:
- Determine which two of the four Green/Yellow conductors are the +12vdc from the two brake switches.
- Join these two conductors together.
- Attach the (now joined together) two Green/Yellow conductors to the 'input' terminal of the brake light flasher device.
- The two remaining Green/Yellow conductors will be the individual brake lamp bulb connectors, join these two conductors together.
- Attach the (now joined together) two Green/Yellow conductors to the "output' terminal of the brake light flasher device.
If the brake lamp flasher device requires a "on with ignition" connection to +12vdc, you might consider using the Black/Brown (tail lamp) conductor as a source.
You should now have flashing brake lamps when either the front, the rear, or both brakes are applied.
