best brake pads?
Vancouver, WA
2007 GL1800
8714
Surprise that EBC didn't even get a vote. I like and still use EBC, front and back
In years past, there were many who tried EBC pads and had issues with fitment around the rotor. Lots of drag, pad wear and rotor wear issues. Last I checked on this was about three years ago. I use OEM. I still haven't needed to replace mine. They have about 27,000 miles on them. :)
Natchez, MS
'07 ST1300
Replaced with oem.... Rears early on after buying the bike new, in 08, an '07..., Was a little heavy on back brake pedal.... Just changed front pair at 30,000 miles... Rears still look ok but will change soon and flush fluid
New Zealand
St1300 '11 (frm new)
Interesting discussion.
Some seem to get really good distance out of the OEM pads. I've owned the St13000 from new and My fronts are almost down to the metal on the leading edge at 30500km ( /8x5=19000miles). I'm quite light on the breaks really as I'm not a high speed rider and I engine break into the corners mostly.
I'm replacing with Ferodo FDB2196St on the front and FDB2098P on the rear both recommended for the ST1300. I'll come back with initial feelings and in 4 years with wear statistics :)
kankakee
R1200rt
I bought a set of Kevlar reinforced pads . 20 bucks front and rear pads, two years and have no issues. cant say if the stop better, which they are suppose too, but the stop as well as the last set. no noise very little dust..
Dahlonega, GA
2018 NC750X
7666
I like OEM pads, they do a good job. However, I actually run EBC on both my bikes. I pull a trailer with the wing when riding two up and want the extra stopping power with the double H pads. One thing to be mindful of if running HH's on a standard braking system... if you grab a handful of brakes in a panic situation like critters in the road... be prepared for the consequences. I recently rebuilt all the calipers on my ST1100 and have EBC HH's on it... to be honest, it can stop, but refer to my previous statement!
OEM ST1300 pads are HH.
Blrfl
Natural Rider Enhancement
Northern Virginia
Fast Blue One
4837
That doesn't necessarily mean they're EBCs. HH is the highest rating in the U.S. DOT's system for describing pad friction. EBC co-opted it for its own use.
I can't say I've ever run into a situation on the ST where I wished the brakes were grabbier, so I stick with the OEMs.
--Mark
--Mark
????? I meant that OEM pads are HH rated because the previous posted indicated that they were not and EBC HH pads were.
Fort Worth, Texas
91 ST1100/06 ST1300
Just curious. There are several styles of aftermarket pads out there at a range of prices. What material are OEM pads? Kevlar, Sintered something or another?
New Zealand
My apologies to all I'm just too pedantic.
Getting the old front pads out and having a look there is still a millimeter off the wear mark front and rear they are only half worn compared to the new ones, so I reinstalled the original front ones and replaced the rear as that set were only $nz45. So I'll get another 30.000km easily from the front, which is just under 40000mls.
Thanks for that tidbit, I just looked at the Ferodo brake pads I bought yesterday and they are Sintered HH.
Cheers
Just to throw another variable into the equation, what application are the pads designed for? For example, Ferodo sometimes makes pads for racing applications (or at least they used to). Those types of pads are designed to be heated up quickly, and run hot, at lower temperatures they don't work as well. So for touring and light sport riding they aren't your best choice. I had that issue years ago with a set of Galfer pads that were described as "superbike" application. They worked well when I heated them up in hard twisty riding, but for around town braking they didn't reach the proper temps for optimum friction on my ST1100. Also used the Ferodo racing pads back in the '90s on a sportbike because I found a killer deal on them, same story.
New Zealand
Thanks for that knowledge bite, very relevant.
I decided since I didn't need them for a couple more years I'd take them back and exchange for something I do need.
I'm not demanding on the bike so best just go stock then I don't need to make a decision.
Tacoma, Wa
Has anyone used the Good Fren brand pads? If so do you like them?
skipcurt
Skip
Woodstock, GA
'18 BMW R1200 GSA
3156
Hey all, probably going to be replacing both sets of pads real soon and was wondering where the OEM purchasers have bought them. Local shop or online somewhere? Front and rears the same? Thinking about these. Can't seem to find pn#s in the catalog.
Skip
