I could not pass up this 94' ST11 with 11k miles on craigslist two weeks ago. I knew it to be running a bit rough, it seems a little better after the Seafoam Rx, however its still choppy and rough. Noticed some back fires on deceleration and its just real boggy. I know the bike sat for some time, PO son is a mechanic and went through the carbs to get it going. He did not know anything about syncing the carbs but He did use a temperature gun to check the head pipe temperature, and adjust. Also, looking deep into the tank I noticed RUST. Probably from the long nap it just took.
In the meantime, my brother is flying in for a Yosemite Park trip next month, so I need to get them ready for the road.
-My plan is to clean up the tank-remove all rust
-New fuel filter and new fuel
-Already changed oil and oil filter
-Replace air filter and sub filter
Now run the bike for a bit and see how it responds to the above, probably do another Seafoam treatment then:
-Sync the carbs
-replace plugs
Run the bike again and recheck results
Other than completely removing an working the carbs, What else should should be priority to get this bike off the boggy and choppy list.
If I can get it to really purr, I will do the same to the other bike. Your input here is appreciated!
........Thanks Rod
-Sync the carbs
-replace plugs
........Thanks Rod
