Never had an issue with the rad yet, but it seems worth checking if either sides, air or water have restricted flow (had that on my Toyota once; temps raised slightly above normal while requesting power from the engine at 100mph, temps dropping instantly when going like 60 or less... turned out that corroding fins had squeezed the water passages, reducing the flow, enough to raise the temps when more fuel is burned)ST1100Y, Will check and clean the radiator itself, what is your implication regarding a new water pump?..I'm pretty sure it's the original
There have been reports on this forum about corroding pump-impellers; wrong/never replaced coolant/use of tap-water can cause the blades to rust away...
Such should be somewhat visible when starting the cold engine and peeking into the open radiator neck while its warming up (never whack the throttle while radiator cap is removed!)
Already in idle the pump should blow a well noticeable stream of water blown through the small bore in the t/stat plate; once the t/stat starts to open a significant swell of coolant should get visible... (stop the engine then or quickly place the cap back on, as otherwise the expanding coolant will cause overflow...)
