I'm reposting this as I realized much of it didn't belong in the intro section.
I've been curious about moving up from my '80 CX500 to something more modern and have been eyeing a 4-5th gen VFR, or an ST1100. I've located a '95 ST1100 just miles from my house - but it has a bad fuel pump and the current owner is trying to retrofit it with a pump and regulator. Apparently the OEM pumps are outrageously priced and I wondered how big of a retrofit project it should be? We were able to fire it up briefly after some fiddling but it over pressurizes the float bowls and gas flows out the overflow tubes right away. We only ran it about 10 seconds but it sounded like an engine. I realized I'll need to clean the tank and probably coat it, and might have to kit the carbs as well. I do have an ultrasonic cleaner at least. I looked through the fuel pump thread which is pretty long - is there a general consensus on what works as a reasonably priced replacement to the OEM one?
It's currently a barn find, and all very dusty and panels are off - nothing more than some fading and a couple of cracks, but no serious damage that I can tell. Lights, horn starter all work. Brakes aren't frozen. It needs new set of keys and locks but seems like a viable project. I want to head back and give the swingarm a look too, and if we get it running again, will check the output from the alternator. Timing belt would be on a short list of things to replace. I think mileage was in the mid 50's. Thoughts, comments, concerns?
Any advice is appreciated!
Dan
Dan
